iank
| posted on 17/2/10 at 10:09 AM |
Radiator sizing
When I was having my hallway replastered I took off the radiator so he could do a good/easy job. Left it propped against the wall of my house for an
hour or so (4-5m from the pavement in a quiet cul-de-sac) and some thieving scrapman decided to take it away without asking.
So I need to buy another one to finish the job. But I'm coming up with a blank on how they are sized. The distance between the outside faces
of the taps is 135cm, but the only radiators it seems possible to purchase from regular diy places are either 1200mm or 1400mm.
Can anyone confirm whether that measurement is across the outlets or the panel? I can't seem to find any good drawings on the web that make it
clear.
Taking up 15cm with those extendible valves seems too far.
Don't really want to spend £100 on a plumber draining the system and moving a pipe a few cm.
Any other DIY solutions?
Anonymous
tegwin
| posted on 17/2/10 at 10:17 AM |
Find your local plumbcentre... their catalogue has about 100 different sized radiators in there...
Failing that... get a radiator that is slightly too short, and extend the pipe connections using compression fit gubbins from homebase
www.verticalhorizonsmedia.tv
bob tatt
| posted on 17/2/10 at 10:40 AM |
you will need a 1300mm rad from some where i know the merchants i use does not have that sixe at all any more, although others may. if you cant get
one but a 1200mm and get some rad valve extenders these come in lots of different sizes.
rob
matt_claydon
| posted on 17/2/10 at 12:52 PM |
Plenty of 1300mm radiators available if you search Google / eBay.
Or you can use a 1200 and do something like this: http://www.letsfixit.co.uk/html/plumbing_faq.html#1200MM_RAD
iank
| posted on 21/2/10 at 01:01 PM |
Excellent suggestion, plumbcentre had a Myson 1352mm long, bit of a squeeze getting the tails into the valves but it's on and seems water tight
at the moment (hate plumbing!)
Anonymous
