Author: Subject: Degreaser recomendation req
mangogroove
posted on 4/5/04 at 11:32 AM Reply With Quote
Anyone recommend a good commercial degreaser (not Gunk) (Gunks so watered own dishwashing liquid is stronger)
Cost and where to get it
Thanks in Advance
flak monkey
posted on 4/5/04 at 11:34 AM Reply With Quote
There is a cleaner called Spectroklenz. Its good stuff and dissolves off grease and crud pretty quick. Just use a spray bottle to put it on, leave it a few seconds than wipe it off. Though it will take paint off if you leave it on ages, and it will make bare steel rust if you dont wipe it off properly.
Its one of the best cleaners i have used for a while.
Heres a link to a site that sells it in the uk;
http://www.stage-electrics.co.uk/sfi?27340397
Not cheap...but really good stuff...and its non solvent
Hope that helps,
Sera
http://www.motosera.com
posted on 4/5/04 at 11:59 AM Reply With Quote
POR-15 have a degreaser called Marine Clean, which I've found to be very effective when used either neat or at a 1:1 dilution.
Various health warnings when neat, but bio-degradable and environment friendly when washed off with loads of water.
I know it works, 'cos the steel bits rust very quickly if I don't give 'em some rapid treatment!
DaveFJ
posted on 4/5/04 at 12:00 PM Reply With Quote
the best stuff available - MEK
warning though this stuff is completely EVIL - try a quick web search and you will find that if not treated with care this stuff will do extremely nasty things to your health, and then spend all your money, crash your car and shag your wife!
http://www.seamarknunn.co.uk/catalog/items/item3236.htm
Dave
Mr G
posted on 4/5/04 at 12:31 PM Reply With Quote
White Spirit? Coca Cola? Citrus?
mmmmmmm...... Shaken not stirred
http://www.v8capri.clubonline.org.uk/forum/topic.asp?TOPIC_ID=851
posted on 4/5/04 at 01:24 PM Reply With Quote
Once described by a friend of mine, as he gave me a small jar of the stuff, as "I wouldn't describe it as 'inflamable'... 'explosive' would be a better description" He told me that the best way to dispose of any that I didn't want is just to leave the top open in the fresh air for a half-hour or so - it's that volatile.
The fumes are best avoided, as well.
Great for cleaning out airbrushes, though!
DaveFJ
posted on 4/5/04 at 01:54 PM Reply With Quote
Another solvent that is readily available (when the wife's out! ) is nail varnish remover... the cheap stuff, not the fancy stuff with moisturiser...
Vey similair to MEK... just don't get caught or it will cost you a trip to the makeup department at debenhams....
Dave
posted on 4/5/04 at 02:05 PM Reply With Quote
Jizer and a stiff brush. It's safe.
Terrapin_racing
posted on 4/5/04 at 02:19 PM Reply With Quote
Commercially available Acetone (nail varnish remover) from glassfibre suppliers (glassplies stockport etc.) is one of the friendlier solvents - cheepish too compared to some. Usually comes in gallon cans
Donners90
posted on 4/5/04 at 05:19 PM Reply With Quote
Jizer (not the bio version)
Made by DEB. Awsome at removing all kinds of burnt-on oil and grease. Available here and I would recommend it. I works wonders on old engines!
http://www.tool-up.co.uk/shop/diy/SWAJIZ609.html
The Shootist
posted on 4/5/04 at 09:12 PM Reply With Quote
Not known to many, but....
Powdered laundry detergent, at 1/2 cup per gallon of water, and keep to a low simmer over a gas burner.
Will strip aluminum to a shine, unless you leave it too long. Will even cut the carbon deposits in a cylinder head.
It needs to cook for a half hour or so, but this often gives a little time to watch TV get a fresh beer, or get more parts ready for the bath.
After boiling just brush and rinse with hot water.
Warning ferous metal must be treated or it will rust! I have painted directly after this process on many occasions.
Mark Allanson
posted on 4/5/04 at 09:35 PM Reply With Quote
Loads of good suggestions, I have always used either parafin or gunwash, or both.
Cheap, effective and politically incorrect!
NS Dev
posted on 4/5/04 at 10:14 PM Reply With Quote
Gosh Mark, I'm doing lots of agreeing with you today, what's happened!
I use exactly the same as you! First wipe off the real crud or pressure wash. Then wash in paraffin (Just read the label on Jizer, you'll soon just use paraffin instead, jizer is 95% paraffin + 4% detergent +1% other stuff), then blast with my spray gun filled with 50/50 panel wipe (or gunwash) and cheap thinners (around a fiver a gallon each for these, the paraffin I get from work for £5 per 10 gallons)
The hot alkaline wash has much to recommend it as well. Just use the dishwasher, it does an excellent job and there is a great supply of proprietary degreasers at the local supermarket to go in it!!
