<<  1    2  >>
Author: Subject: low cost welding gas: lemonade?!?
dinosaurjuice
posted on 23/6/10 at 06:34 PM Reply With Quote
always wanted to know if this would work or not
not sure how much gas there is in 2l of lemonade but at 21p a bottle must be fairly cheap way of getting CO2!
back out to garage to give it a try.... pictures to follow!
Will
Dangle_kt
posted on 23/6/10 at 06:42 PM Reply With Quote
my welds are bad enough without having to shake a bottle of pop with one had!
SeaBass
posted on 23/6/10 at 06:46 PM Reply With Quote
PMSL. Has to be a picture of the year on here.
dinosaurjuice
posted on 23/6/10 at 06:50 PM Reply With Quote
dissapointing
works OK for 2 seconds, but then the pressures goes. now all i need is an automated shaker...
Will
Irony
posted on 23/6/10 at 07:22 PM Reply With Quote
Are soda stream canisters more or less exspensive than regular C02 bottles
omega0684
posted on 23/6/10 at 07:29 PM Reply With Quote
surely your wallet can stretch to a £10 cannister from Halfrauds!
blakep82
posted on 23/6/10 at 07:30 PM Reply With Quote
what about if you breathe through the co2 hose?
________________________
Guinness
posted on 23/6/10 at 07:40 PM Reply With Quote
You're not that efficient, the air you breathe out is only about 4.5% CO2.
Davey D
posted on 23/6/10 at 07:41 PM Reply With Quote
Do you ever watch myth busters? Mentos in a bottle of coke, or a load of Antacid tablets in water should do the trick
mcerd1
posted on 23/6/10 at 07:58 PM Reply With Quote
^^ but wait till one of us is there with the video camera
cadebytiger
posted on 23/6/10 at 08:06 PM Reply With Quote
I can get dry ice from the lab - that should do the trick
indykid
posted on 23/6/10 at 08:08 PM Reply With Quote
if you can get home quick....
scudderfish
posted on 23/6/10 at 08:17 PM Reply With Quote
Put the bottle on the rocker cover of your engine. Remove one spark plug and start it up. The vibration and heat should do a good job of getting the CO2 out of the lemonade.
posted on 23/6/10 at 08:21 PM Reply With Quote
OFten tempted to hook up a tube to some liquid nitrogen and see what happens. Would certainly be inert
dinosaurjuice
posted on 23/6/10 at 08:23 PM Reply With Quote
thats an option, but this way i get 94 litres of flat lemonade to drink afterwards.
Canada EH!
posted on 23/6/10 at 08:24 PM Reply With Quote
And the lemonade tastes flat after! idle hands are the devils workshop.
scudderfish
posted on 23/6/10 at 08:25 PM Reply With Quote
If you're worried about flat lemonade, you could always buy some CO2 and recarbonate it.
T66
posted on 23/6/10 at 08:33 PM Reply With Quote
Cheapskate savers Lemonade
should of used schweppes you amateur !
mcerd1
posted on 23/6/10 at 08:36 PM Reply With Quote
PMSL
dinosaurjuice
posted on 23/6/10 at 08:51 PM Reply With Quote
might improve the weld penetration
MakeEverything
posted on 23/6/10 at 10:10 PM Reply With Quote
He's a secret lemonade welder......
Kindest Regards,
Richard.
blakep82
posted on 24/6/10 at 07:02 AM Reply With Quote
could last quite a while with a regulator on there actually
Grimsdale
posted on 24/6/10 at 07:48 AM Reply With Quote
You've got to try this method, altho it might be better with sparkling water.
Nice speaking to you at newark DJ
[Edited on 24/6/10 by Grimsdale]
wilkingj
posted on 24/6/10 at 09:40 AM Reply With Quote
Why all the effort for poor quality or dubious welds.
You are going to drive this car on the public roads. You are possibly putting your life and others at risk by not doing your welding correctly.
How much are you really going to save?
Is it really worth the saving considering the potential safety aspect?
Whilst it might be fun to try it as an experiment. I Know I would never risk it on a motor vehicle of any kind.
If a job is worth doing... Then do it properly.
Best Regards
Geoff
http://www.v8viento.co.uk
dinosaurjuice
posted on 24/6/10 at 11:41 AM Reply With Quote
lol. it was only a bit of fun. i have a bottle of proper gas when im doing anything important.
will
<<  1    2  >>
