Author: Subject: CPU overheating
Davegtst
posted on 3/7/10 at 11:11 AM Reply With Quote
CPU overheating
My pc cpu keeps overheating causing the pc to shutdown. I've got an amd 6000+ cpu with the stock heatsink and fan which is pefectly clean and working properly. As it's a bit warm lately the temp gets right up to 85 degrees then shuts down, this is only while gaming. Can anyone recomend an upgraded heatsink or fan that will keep it cool but not be too expensive. There are so many out there it's difficult to know what is best.
nitram38
posted on 3/7/10 at 11:12 AM Reply With Quote
Extra case fans will help a lot
posted on 3/7/10 at 11:14 AM Reply With Quote
Yup. Make sure the hot air coming off the CPU is able to leave the box. A utility like Speedfan will let you monitor you HD temps, chassis temps etc etc. It's likely that they are all going up rather than just the CPU temp.
l0rd
posted on 3/7/10 at 11:28 AM Reply With Quote
yes a proper non intel or amd cooler.
Tuesday i bought the Scythe Big Shuriken
Was out of stock though and i am still waiting. This will go though on a really small cube computer where height is important.
Also bought some coolink fans. Quite impressed.
Davegtst
posted on 3/7/10 at 11:52 AM Reply With Quote
I'm using speedfan to monitor the temps. Even with the side cover off it still overheats (only on certain games) which is why i think i need a better fan.
[Edited on 3/7/10 by Davegtst]
Ninehigh
posted on 3/7/10 at 12:26 PM Reply With Quote
Has the fan got a heatsink on it? Might be worth attacking it with a vacuum cleaner as last time this happened to us there was a film of fluff over it.
RazMan
posted on 3/7/10 at 12:27 PM Reply With Quote
Did you try cleaning the cpu and heatsink mating surfaces and re-applying some good thermal compound like Arctic Silver?
Raz
posted on 3/7/10 at 01:43 PM Reply With Quote
I had over-heating until I fitted second chassis fan. Couldn't be arsed to fit a controller so just added an inline toggle switch on the back of the computer
gaming mode = flip the switch
simples
UncleFista
posted on 3/7/10 at 01:50 PM Reply With Quote
I used to have a tower with a few extra fans, the one that worked the best by far was a "chimney" fan on the top blowing the warm air out. It was cooler than leaving the side off, somehow...
I have lots of single application heat sink paste if you want some ?
Tony Bond / UncleFista
stevebubs
posted on 3/7/10 at 02:08 PM Reply With Quote
My money would be on not enough paste between CPU and cooler...
UncleFista
posted on 3/7/10 at 02:09 PM Reply With Quote
Or too much
gottabedone
posted on 3/7/10 at 03:20 PM Reply With Quote
as Unc says, too much will insulate the cpu instead of filling the gaps between the mating surfaces and conducting the heat into your heatsink. The AMD 6000 cpu is also chucking out 125 watts so tidy your cables to allow the air to flow through the case and get your fans blowing the air/heat out. Check to see if it needs a good clean as this can cause overheating.
Liam
posted on 3/7/10 at 04:10 PM Reply With Quote
Are you overclocked? If not, the stock cooler should be sufficient, so if it isn't I'd suspect a poor seating on the CPU if you're sure it's not full of dust. Get some decent paste and make sure it's seated properly. Could also be poor case airflow so maybe think about improving that. I'd leave an aftermarket cooler as a last resort after first trying the above, unless of course your CPU is overclocked, then it's no suprise the stock cooler is struggling.
[Edited on 3/7/10 by Liam]
Davegtst
posted on 3/7/10 at 04:21 PM Reply With Quote
No it's not overclocked and i recently got all the dust out with the airline and reseated it with new paste. It was playing up a bit until i dusted it out and reseated the heatsink but since then it's been fine. I have 3 extra case fans and it's been fine until i tried a new game today.
posted on 3/7/10 at 09:15 PM Reply With Quote
Even if you're running Prime95 on torture mode you still shouldn't be over-heating.
Another mod I made on my case was having an inlet fan on the front of the case. After all no point having fans sucking out the air if it's struggling to get into the chassis...
posted on 3/7/10 at 09:17 PM Reply With Quote
Just another thought. Have you got good airflow over your graphics card? Often the GPU card sits under the CPU and unless you've got good air flow the GPU (when gaming) will be blowing damn hot air right onto the CPU. On some motherboards the PCI express socket is ridiculously tight up against the CPU / heatsink combo. Then the graphics card fan just works as a pre-warmer for the CPU air!!!
?? worth rigging up a fan to blow colder air onto the GPU?
l0rd
posted on 3/7/10 at 10:14 PM Reply With Quote
I just read that there is an issue with these processors and the internal sensor.
Might worth looking on google
Davegtst
posted on 4/7/10 at 08:32 AM Reply With Quote
Well i took the heatsink of just to check then put it back in place and it's not overheating now. Still says it gets up to 80 degrees but i didn't shut down for a few hours. The graphics card is an nvidia 280 gtx with it's own fan, the thing is huge. I do have to turn the gpu fan up via Ntune to get decent cooling though.
Davegtst
posted on 4/7/10 at 09:10 AM Reply With Quote
Just been reading about 6000+ cpu's getting hot and it seems people think the stock fan and heatsink aren't up to the job. I've just bought one of these to see if it reduces the temps.
http://www.play.com/PC/PCs/4-/14259650/Arctic-Cooling-Freezer-64-Pro-PWM-CPU-Cooler/Product.html
Davegtst
posted on 10/7/10 at 08:08 PM Reply With Quote
Just a quick update if anyone is interested. Got the cooler yesterday and fitted it, so far it will not go any higher than 60 degrees with it under high load. 25 degree drop in temp and no more crashing is pretty good i reckon
Liam
posted on 10/7/10 at 08:46 PM Reply With Quote
Glad it's sorted.
