omega0684
| posted on 26/4/09 at 07:41 PM |
CF Pipercross Backplate
well considering pipercross charge an absolute fortune for there kit i decided to have a go at making my own back plate. took me a couple of hours to
do the template and cutting but i think it looks alright, just got to do an airbox now
im quite chuffed with myself.
[Edited on 26/4/09 by omega0684]
blakep82
| posted on 26/4/09 at 07:43 PM |
ooh thats special
________________________
RichardK
| posted on 26/4/09 at 07:47 PM |
If thats the template can't wait to see the real thing
What did you use to cut out the template
Rich
Gallery updated 11/01/2011
omega0684
| posted on 26/4/09 at 07:51 PM |
if real CF, used a jigsaw (very carefully) and a file. 10mm drill bit for the holes.
RichardK
| posted on 26/4/09 at 07:53 PM |
Nice work m8, should be proud of that...
twybrow
| posted on 26/4/09 at 08:11 PM |
Looking good. How many splinters have you now got in your hands?
clairetoo
| posted on 26/4/09 at 08:12 PM |
Airbox ? How about one of these
  Carbon airbox
And here's a backplate I just knocked up for myeates (to go with the throttle bodies I have nearly finished )
[img][/img]
Its cuz I is blond , innit
Claire xx
Will weld for food......
omega0684
i think i got between 5-10 splinters and man they hurt!
claire i have the measurement for the inlets on mine if you want it
claire, are you going to do a mould with a slanted inlet?
clairetoo
| posted on 26/4/09 at 08:39 PM |
The measurements would be handy !
Do you mean a `box with an angled inlet (to get it inside the bonnet ?)
Claire xx
omega0684
| posted on 26/4/09 at 08:45 PM |
yeah
the external diameter of each of the inlets is 46.8mm, so i reckon if you made the internal diameter of the step at the bottom of the trumpet 47mm
they should be a snug fit, also the bottom stepped part needs to be about an inch long.
flak monkey
| posted on 26/4/09 at 08:49 PM |
Looking good Alex.
Stick with a foam filter....will flow much better than an airbox with a single small inlet.
Sera
http://www.motosera.com
omega0684
| posted on 26/4/09 at 08:59 PM |
yeah i know mate but the air temperature that the sensor is reading on MS says 45 odd degrees, so the airbox that claire can make fits over the top of
the pipercross filter and an then you just run a pipe down into the nose cone to get some nice fresh air into the box rather than having hot air
sucked in
