Author: Subject: Fire Extinguisher Fail
graememk
posted on 8/6/09 at 12:50 PM Reply With Quote
ok there is a serious side to this post.
Whilst sat in my shop saturday there was a quite big bang, anyway see pic.
fefailb
fefailb
It was sat on the floor not on a wall bracket, turns out that it got damp and rusted through, untill it went bang, however just to show what damage this would cause in the garage.
it removed the sink from the wall leaving it hanging from the waste pipe, dented the radiator and put a hole in the stud wall.
so all you guys with a fire extinguisher in the garage check it for rust around the seams, and hang it on the wall to stop it rusting. this was an old one i just kept in the back just in case i needed it.
[Edited on 8/6/09 by graememk]
posted on 8/6/09 at 12:53 PM Reply With Quote
Lucky no-one was near it when it went off
balidey
posted on 8/6/09 at 12:54 PM Reply With Quote
bloody hell
[Edited on 8/6/09 by balidey]
tegwin
posted on 8/6/09 at 12:55 PM Reply With Quote
Jesus... thats not good!
I guess thats why they insist on safety tests in industry!
www.verticalhorizonsmedia.tv
graememk
posted on 8/6/09 at 12:56 PM Reply With Quote
well i know that the discharge time on that one was about 2seconds.....
blakep82
posted on 8/6/09 at 12:57 PM Reply With Quote
i've only got a small one (fire extinguisher ) but always kept on the wall
you see fire extinguishers every day, you never thing about the pressure inside them.
________________________
speedyxjs
Stuart_B
posted on 8/6/09 at 12:58 PM Reply With Quote
wow, that could have been bad, if you were near it, i will check mine when i get home.
stuart
posted on 8/6/09 at 01:07 PM Reply With Quote
Looks like it has failed on a seam?
posted on 8/6/09 at 01:24 PM Reply With Quote
Ye gods! I suppose it's likely to happen, aren't they filled with weak sulphuric acid?!?!?
Mr Whippy
posted on 8/6/09 at 01:38 PM Reply With Quote
never heard of this before, all mine are aluminium cylinders so their fine
I think that would have killed someone quite easily
carpmart
posted on 8/6/09 at 01:43 PM Reply With Quote
That really could have been nasty!
'94 MX5 MK1, 1.8
F10 M5 - 600bhp Daily Hack
Mercedes A class - Son's Car
blakep82
posted on 8/6/09 at 02:16 PM Reply With Quote
make you wonder though, if they can explode so violently, why haven't they found anything better instead?
think about a burning building with a few of them, getting really hot, surely they must explode?
dave107
posted on 8/6/09 at 02:47 PM Reply With Quote
Yes potentially very dangerous and if you are running a business and that had blown up in someones face you could probably be put out of business and end up in prison, most of these types of extinguisers are between 9 and 15 -16 bar pressure, lucky it wasn't Co2 with 170-200 bar pressure could blow your window or door down and kill someone aluminium ones would split but steel ones could shatter and cause a huge problem to anyone in the room.
That is why they are supposed to be off the floor and serviced every year and taken out of service betwwen 7-10 years.
http://www.fireprotectiononline.co.uk/news/6/Fire-Extinguisher-Maintenance-an-Essential-Part-of-Fire-Safety.html
See link
l0rd
posted on 8/6/09 at 03:11 PM Reply With Quote
Could we get pics of the damage?
lsdweb
posted on 8/6/09 at 03:20 PM Reply With Quote
Is that rust we can see near the seam???
No sulphuric acid in them these days -soda acid extinguishers disappeared years ago (hopefully!)- if you've still got one with acid in change it!
graememk
posted on 8/6/09 at 03:35 PM Reply With Quote
yes that would be rust you can see, but its well hidden behind the plastic cover and the powder coat
myke pocock
posted on 8/6/09 at 03:51 PM Reply With Quote
Most, if not all, are plastic lined to help prevent corrosion from the inside. That, however, doesnt cope with corrosion from the outside. Fortunately i get my trials car extinguisher checked when they visit work (and it dont cost me!!!)
big_wasa
posted on 8/6/09 at 04:39 PM Reply With Quote
sickbag
posted on 9/6/09 at 08:46 AM Reply With Quote
Makes me think that maybe the £15 a year it costs for my two to be inspected is well worth it now.
Finally back on the job!
