Author: Subject: O.T. Hole saw in marble?
tegwin
posted on 20/6/09 at 09:11 AM Reply With Quote
Can I cut through a section of marble worktop with a normal hole saw?
Or what other tool would be better....
I need to make holes for pipes etc
www.verticalhorizonsmedia.tv
owelly
posted on 20/6/09 at 09:14 AM Reply With Quote
You'll need diamond dust hole saws. Can't think of another way.
http://www.ppcmag.co.uk
zilspeed
posted on 20/6/09 at 09:32 AM Reply With Quote
Water jet
iiyama
posted on 20/6/09 at 09:47 AM Reply With Quote
Diamonds or waterjet .....or a shaped charge!
If its broke, fix it. If it aint broke, take it apart and find out how it works!
spewing
posted on 20/6/09 at 12:02 PM Reply With Quote
Try
http://365drills.com/
Much cheeper than the other options.
Depends how thick the marble is but you should get through with just one hole saw
Kev
posted on 20/6/09 at 12:05 PM Reply With Quote
When I've seen people using a hole-saw in stone (inc. marble) they were using a water spray to help to cool the saw - just a hand-pump spray, like you'd use on plants.
I'd guess that it also keeps the marble cold (to prevent overheating and cracking) as well as keeping the dust down.
Bet it makes a mess, though...
UPDATE: those 365 drills don't seem to need water.
[Edited on 20/6/09 by David Jenkins]
