<<  1    2  >>
Author: Subject: Stafford show
undecided
posted on 13/3/04 at 06:29 PM Reply With Quote
Stafford show
Hello,
Being new to kit cars i decided to go to Stafford and was wondering why two cars on show looked so much alike.
one in question the MK Indy i have heard of as they advertise in magazines the other the Type lr i hadn't.
So many parts looked th same dos anyon know if they are th same car?
Staple balls
posted on 13/3/04 at 06:44 PM Reply With Quote
Type lr is a mac#1 thingy?
didn't mac#1 used to build/sell MK's then set up on their own using similar designs?
greggors84
posted on 13/3/04 at 06:47 PM Reply With Quote
Type lr? is that from MAC 1?
A few kits have taken styling cues from MK, some might have used their panels as a mould (who knows).
The MAC 1s are very similar to the MK. But if you are looking for a MK lookalike you might as well buy an MK as they are the original and as Martin designed it he knows how and why it works, not just that it does like the others.
(i think i heard MK say that at a show once)
Chris
The Magnificent 7!
undecided
posted on 13/3/04 at 07:09 PM Reply With Quote
O dear i take it then that the type lr is a copy of the MK Indy rather than a new design?
mad-butcher
posted on 13/3/04 at 07:25 PM Reply With Quote
and it's amazing how many have built them with back to front and upside down wishbones
Wadders
posted on 13/3/04 at 07:32 PM Reply With Quote
Sorry bloke, but i had to laugh when i read your post. Surely all sevenesque cars are a loose copy of something which dates from the fifties. To say MK's are in some way original is stretching the imagination a bit, to be more accurate the MK is a Caterham lookalike, with running gear more in common with a Westfield.
Nothing against MK's BTW, they are a fine car, as are many of the other Seven clones out there.
Al.
i]Originally postedi]Originally posted by greggors84
undecided
posted on 13/3/04 at 09:17 PM Reply With Quote
Silly question:
When asked what was used for the floor i was told alumiunium chequer plate does this seem right?
undecided
posted on 13/3/04 at 09:27 PM Reply With Quote
I take it then that the use of chequer plate for the floor is not the right solution?
I have briefly read Ron Champion's book but found no sign of using it so had to ask.
Makes me wonder what else is not right!
dozracing
posted on 13/3/04 at 09:49 PM Reply With Quote
Chequer plate?
Thats really poor. Its massively heavy.
I've heard nothing but negative response about Mac, very unhelpful etc.. Everyone has only good things to say about MK, even though they aren't particularly accomodating with customer emails and visits, but thats a reflection of how busy they are.
I know they are all based on Luts 7's etc, but such blatant copying is just so not on. I heard a story that they took an MK to a guy to make jigs from so he could copy the chassis totally. Any fool can do that, it takes a little more intelligence to design something yourself even if you take the concept from other people.
Deckman001
posted on 13/3/04 at 10:03 PM Reply With Quote
undecided
posted on 13/3/04 at 10:05 PM Reply With Quote
oh my word what have i started.
dozracing
posted on 14/3/04 at 12:33 AM Reply With Quote
Actually the curves are the worst part of the MK. Anyone studying engineering knows that you don't feed loads into curved members.
MK do it for production reasons not for structural reasons.
Colin Chapman was a genius and a real engineer. How many curved members were in the original 7?
Staple balls
posted on 14/3/04 at 01:11 AM Reply With Quote
as a not an engineer
but having some idea.
i'd say the curved bits on an indy make little difference strength/stiffness wise and improve how it looks, but i'm waiting to be told otherwise.
also, there's a few things i'd do differently if i was me, but that's unimportant
posted on 14/3/04 at 01:30 AM Reply With Quote
Curved Members
I didn't realise the footwell curve on the MK Indy was under load?
Having said that - I guess all members are under "some" load. However, I doubt this area is critical load bearer...
On modern cars - isn't the crumple zone made from a series of curves, giving sequential/predictive crumpling?
greggors84
posted on 14/3/04 at 01:35 AM Reply With Quote
wadders
if you have seen the mac 1, you will know what i mean, and there has been discussions on this forum about copies of MKs. I know all sevens are replicas of the lotus 7 (except maybe the caterham), but if you are going to buy a certain 7 for the way it looks, and people do, (if i had enough money to afford a westie, i would go for something else, as i dont like the look of them), they might as well buy the original (in this case the MK).
Some people say that the spd was a mk copy (so ive heard) and look what happened there!
[Edited on 14/3/04 by greggors84]
Chris
The Magnificent 7!
dozracing
posted on 14/3/04 at 07:45 AM Reply With Quote
Don't get me wrong i totally appluad Martin for the MK and its success. The curved tubes make it faster for them to make etc.. All tubes in a space frame are loaded thats how they work, and for "ultimate" structural integrity you shouldn't curve them. Thats not saying its not a solution that is acceptable enough.
The MK was the most different of the 7's from the book, and it came first. So the likes of Mac flatter it by copying it, and thats praise for Martin.
If you are an engineer with any skill or experience though there are plenty of things to do to make your 7 stand out from the crowd.
M@Triton
posted on 14/3/04 at 10:29 AM Reply With Quote
This looks to have been a bit heated!!!!!!
Bending tubes is best avoided as is the use of chequer plate unless of course it's a staircase being made!
Staple balls
posted on 14/3/04 at 10:46 AM Reply With Quote
it'd be interesting to see analysis of the MK indy, the gts whatsitcalled, the book chassis and the orignal seven.
i'm not sh!t stiring or trying to start arguments about which is better.
but it'd be nice to see which came out on top
undecided
posted on 14/3/04 at 02:01 PM Reply With Quote
Indeed it would be nice to know which product came out on top after testing, but i noticed that the front man of GTS is an F1 engineer and we all know how techy those people are.
One wouldn't hesitate to suggest that this has already taken place as far as the GTS Locost is concerned.
Noodle
posted on 14/3/04 at 06:04 PM Reply With Quote
I realise that we don't criticise MK in this forum (tantamount to sacrilege ), but it the curvature in the wishbones that have always bothered me.
I can see that they’re made that way because it’s easier and no, I don’t know what loads they really take in the horizontal plane, but it’s clearly not as structurally efficient.
If we’re being really pedantic, and I can be really pedantic, it requires more material to make an arc than to run to straight pieces that join at the apex. More material=more weight.
Neil.
Your sort make me sick
greggors84
posted on 14/3/04 at 06:51 PM Reply With Quote
If any one wants to lend me one of each of the competitors, and an airfield for the day, i will gladly tell you which one (i think) is better!!
p.s. had better chuck in a caterham r500 and some busa engined thing, just so i know how they compare!!
Chris
The Magnificent 7!
ned
posted on 15/3/04 at 10:51 AM Reply With Quote
the chequer plate floor mentioned above was in one of mac1's cars, which as said above is a copy of the mk indy.
i always prefer stright tubes and triangles to curves, though the mk indy is a very good kit, design, originality (in the 7-esque sector) and price. i had an arguement with someone a while back about this!
Ned.
beware, I've got yellow skin
M@Triton
posted on 20/3/04 at 12:25 AM Reply With Quote
No chance....toblerone's in the desert were built by little green blokes.
posted on 20/3/04 at 11:54 PM Reply With Quote
No way!!!
The Egyptians built them as monuments to their great leaders using Nubian slave labourers in their millions. I have seen actual film footage of this on T.V. so it must be true. The Aztecs were in league with aliens though, that's where they got all their strange ideas from.
[Edited on 20/3/04 by Peteff]
M@Triton
posted on 21/3/04 at 10:49 AM Reply With Quote
I live next door to an alien so know for a fact they are real.......strange shiny glow from the top of his head and who knows what language he speaks......who else would polish a wheelie bin!
<<  1    2  >>
