tegwin
| posted on 20/8/09 at 09:34 AM |
Anyone work in indstrial electonics?
Do we have any sparks/systems engineers in the house?
I need a 30A+ dual pole contactor (with a 230-240V coil)... dont fancy paying £80-£150 for a new one...
Does anyone have access to any old equipment etc and would be able to throw me one for some beer money?
(I want to use it to switch on and off an immersion type coil heater)
[Edited on 20/8/09 by tegwin]
www.verticalhorizonsmedia.tv
nitram38
| posted on 20/8/09 at 11:02 AM |
"I want to use it to switch on and off an immersion type coil heater"
Yes, just before the STILL goes bang!
tegwin
| posted on 20/8/09 at 11:16 AM |
STILL?
Its an inteligent heater with soft start on it.. I just need to be able to switch off the power to the unit if the temperature is above 8 degrees....
The "call for heat" signal comes from elsewhere...
Is this not a very clever solution then, using a contactor?
Its a simple (ish) solution for a very comlpicated control problem... Dont you hate it when components have a mind of their own!
t16turbotone
| posted on 20/8/09 at 01:16 PM |
elect. engineer here, i should have a good used one kicking about...u2u me sometime
