Author: Subject: Freelander brake pipe unions - what thread?
MK9R
posted on 7/9/09 at 01:30 PM Reply With Quote
Bit of a long shot but maybe the power of LB can find me the answer????
Got to replace the front to rear brake pipes (going cut in the middle of car and just run new pipe to rear as this where the corrosion is) and the short pieces between the hose and the rear hub. But what size threads are they????
Cheers Austen
RGB car number 9
www.austengreenway.co.uk
www.trackace.co.uk
matt_claydon
posted on 7/9/09 at 01:32 PM Reply With Quote
I don't know the vehicle, but I would be very surprised if they weren't M10x1 - that's pretty much standard these days.
MK9R
posted on 7/9/09 at 01:39 PM Reply With Quote
i had some pipes made up for another one i did about a year ago, and the fittings put on weren't right and ended up cutting them off, buying my own flaring tool and doing it myself reusing the old unions, but the ones on this are are buggered
Cheers Austen
RGB car number 9
www.trackace.co.uk
adithorp
posted on 7/9/09 at 02:32 PM Reply With Quote
M10x1
http://jpsc.org.uk/forum/
posted on 7/9/09 at 02:53 PM Reply With Quote
Best to use a proper joiner to join the pipes -- don't just put a male fitting into a female.
posted on 7/9/09 at 07:09 PM Reply With Quote
Must admit I don't like doing it that way BUT Peugeot have been doing it for years on factory fitted pipes.
