t16turbotone
| posted on 11/9/09 at 06:56 PM |
rear disc brakes binding??
hello peeps, just been out for another short blat , i have noticed that after 10 mile or so the rear brakes start to bind slightly?? caplipers are
sierra items and new, handbrake cbles are new and not tight at all.....when i go to car tomorow they will be ok to start off with then they will start
to bind after a short while...standard sierra master cylinder with punto bias valve connected in line to rears...any ideas folks pls??
thanx
| posted on 11/9/09 at 06:57 PM |
Drums
t16turbotone
| posted on 11/9/09 at 07:00 PM |
?? seems a little drastic to change to drums....lol
big-vee-twin
| posted on 11/9/09 at 07:30 PM |
I had a similar problem, turned out to be wheel bearings, was on a Saxo but it felt like the brakes were binding- may be worth checking.
http://www.triangleltd.com
| posted on 11/9/09 at 08:13 PM |
Brake pedal not allowing mastecylnder piston to coming back far enough ?
Also make sure the resevoir isn't over filled.
