Author: Subject: Any boiler engineers?
posted on 18/9/09 at 06:38 PM Reply With Quote
Our combi, a Vokera Linea has lost a bit water pressure on the gauge since not being used for heating since about April, now when I open the fill loop valve theres no movement of water into the system..
There is water pressure in the fill loop up to the valve on the CH....
Any ideas?
liam.mccaffrey
posted on 18/9/09 at 06:48 PM Reply With Quote
Sorry this is a pet hate of mine. Someone who installs and repairs domestics heating system is NOT a boiler engineer!
Whats wrong with being a technician?
This isn't a dig at you mate, I hope you get your problem sorted
Build Blog
Build Photo Album
t16turbotone
posted on 18/9/09 at 07:12 PM Reply With Quote
probaly the non return valve stuck, which is usually incorporated in filling loop
jonesier1
posted on 18/9/09 at 07:20 PM Reply With Quote
flow valve stuck ?
im in my own little world...its ok though they know me there
posted on 18/9/09 at 08:03 PM Reply With Quote
Obviuos, what I want to know is how to fix it...
maskell01
posted on 18/9/09 at 08:21 PM Reply With Quote
1)Take the massive hammer out of ur tool box.
2)Raise the said hammer high above your head
3)Swing the hammer,aiming it at the problematic isolation valve.*
*At this point a noise for effect is optional,something like "UGGGGGGH" usually does the job and makes it sound manly too!
If this doesn't do the job run like buggery to the nearest phone as you probably just split a pipe you didnt want to!
posted on 18/9/09 at 08:49 PM Reply With Quote
Right, I'll phone the gas board.....
NS Dev
posted on 18/9/09 at 10:01 PM Reply With Quote
well, if you can build a car..............
sorry!
If the main system is holding some pressure (i.e. not zero) then its pretty likely the fill valve. In which case the only answer is turn the cold water supply off at the stop tap, dismantle the filling loop, find the fault and replace the appropriate valve.
Strange one though, which i guess is why you asked!
I'm no boiler engineer!! I don't like to pay somebody else to do my fault finding either though, they always take longer, do a worse job and cost a lot!
Stott
posted on 18/9/09 at 10:12 PM Reply With Quote
does this help, 6.23?
http://vokera.excaliburstudio.co.uk/wp-content/uploads/2009/04/linea-he-combi-boilers-installation.pdf
Paying someone is always the last resort
