prawnabie
| posted on 1/10/09 at 06:06 PM |
Winter mods???
Driving to work today on leaf covered roads make me thing of planning the next round of winter mods. What are you planning?
Myself I will be installed a higher pressure oil pump, remote filter and an oil cooler. I am also going to change the headgasket and re-plumb the
cooling system with a header tank.
flak monkey
| posted on 1/10/09 at 06:08 PM |
Finishing the supercharged Duratec install once all my parts arrive
Making my new garage water tight and relatively dust free.
Lots of DIY on the flat.
Sera
http://www.motosera.com
chris_smith
| posted on 1/10/09 at 06:11 PM |
engine upgrade from xflow to zetec, and complete new paint job and hopefully smaller headlights, chassis to be stripped and re painted too
how long is winter????
chris
James
| posted on 1/10/09 at 06:31 PM |
Doing all the post-SVA things I never got round to doing when I passed 3 years ago would be a start!
Then there's the interior that needs re-doing, the dash need re-doing or atleast re-inforcing.
Test the new radiator setup.
Sort the leaky filler neck hose (turns out the fuel resistant hose bought at great expense wasn't :mad
Setup the suspension properly front and rear.
Raise the rear wheel arches.
Fit the 3rd brake light
Fit fire extinguisher
Get the new seats/sliders in properly.
Probably a few things more.
James
- Muhammad Ali
YQUSTA
| posted on 1/10/09 at 06:54 PM |
Engine swap
rewire the engine
make some new parts including a bonnet scoop and new bulk head from carbon.
and with alot of luck I would love to make use of the 3.38 diff thats been sat in the shed for some time.
"If in doubt flat out"
Colin McRae
| posted on 1/10/09 at 07:02 PM |
Finish the soft-top
Make up an EFi plenum with injectors (MIG ali tack welds then off somewhere for some TIG)
Get an adaptor made up to mount the new pulley wheel onto the crank pulley.
Whip the Honda ECU stock spark map (ie using a timing card and strobe)
Put above spark map into Emerald as a base map
Get the Innovate LC1 onto the car (on the exhaust without the leak at the headers!!)
Sort out fuelling
Maximise maps for POWER
That's enough for one winter
Though ideally I'd also like to get the dry sump conversion done and dusted...
.... and the blower cradle added....
RichardK
| posted on 1/10/09 at 07:11 PM |
New dash, rose jointing all the backend
Rich
Gallery updated 11/01/2011
locoR1
| posted on 1/10/09 at 07:22 PM |
Gearbox and diff rebuild for mine spent most of the summer nursing a poorly gearbox through to winter.
Just hope it lasts this month out and doesn't explode must resist from turning the boost controller back up
Check out my CB500T Cafe Racer build diary
omega0684
| posted on 1/10/09 at 07:23 PM |
engine rebuild (almost done), ali panels to be replaced with carbon fibre, fit bonnet scoop. maybe do carbon fibre dash change over, detachable
steering wheel. and need to get carbon fibre arm rests and half doors made. im sure that there are loads of other things but i can't remember
everything!
oh i forgot i have air box to do as well!
and i want to fit a hydrolic clutch
its a never ending list!
[Edited on 1/10/09 by omega0684]
Dangle_kt
| posted on 1/10/09 at 07:58 PM |
Does a first drive count as a winter mod?
Do have some plans, all cosmetic stuff, but depend on money.
Full new glassfibre body kit, sprayed, graphics kit, dash panel, cycle wings, digi dash, tunnel top, interior panels and new harnesses.
Big job, so might leave it till I can face it/have money/have time/have made up with the wife for all the hours I've been in the garage over the
last few years!
| posted on 1/10/09 at 08:19 PM |
Well I have someone coming to view the Indy this weekend so it may be gone soon
If it stays then winter work will include...
1. Fit a 12V power socket under the dash
2. Make and fit a boot box to go under the lockable cover
3. Fit some protection film on the rear arches
4. Make and fit some front mud flaps
5. ooo! Hydraulic clutch - now there's a thought!
Failing that I'll be busy stripping my new donor and refurbing the parts ready for the next project
[Edited on 1/10/09 by nick205]
yellow melos
| posted on 1/10/09 at 08:43 PM |
I will be swapping a 4 wheeled car for a 3 wheeled bike... well.. hopefully
Davey D
| posted on 1/10/09 at 08:48 PM |
for me its something like this:
1) fit new seat mounts/remove sliding rails
2) buy new seats to fit to uprated seat mounts
3) fit some new carbon parts
4) get some race livery stikers
5) remove the parts where the crappy powdercoat has flaked off, blast them, and repaint
6) Fit air induction box, and cool air feed pipe
7) fit Oil Pressure + temp Gauges
8) remove the diff, and get it checked over/rebuilt, as im sure its noisier than it used to be
clairetoo
| posted on 1/10/09 at 10:22 PM |
everything!
And maybe a set of billet alloy multi V pullies
As for mine.....
Make a new bonnet bulge
Paint the whole car.....
Sort out rear exit exhausts......somehow
Swap the whiney gearbox for the spare thats been sat in the shad for 18 months.....
Its cuz I is blond , innit
Claire xx
Will weld for food......
blakep82
| posted on 2/10/09 at 12:39 AM |
mods? still got to finish the first round of the car
________________________
Gergely
| posted on 2/10/09 at 04:46 AM |
1. Fit gear indicator
2. Fit Flatshifter kit
But winter begins in two months, until then we have to have our intake valves replaced, the Power Commander mapped on a rolling road session and test
drive the car on a track...
Gergely
Our build pictures
iank
| posted on 2/10/09 at 06:29 AM |
Make some progress on getting the car on the road
Anonymous
mad4x4
| posted on 2/10/09 at 06:30 AM |
1)Finish Windscreen Mounting (change angle)
2) Change rear Diff to LSD
3) Get a Hood asI have a Windscreen
4) Tune with rolling Road hopefully
Scot's do it better in Kilts.
omega0684
| posted on 2/10/09 at 09:18 AM |
oh and some billet alloy multi V Pullies!
(yes im sticking with the pinto for another year and going to build the duratec on the side!)
cd.thomson
| posted on 2/10/09 at 09:25 AM |
In order from now:
send my rebuilt zx9r carbs off to bogg bros
final fit the the steering column
install the oil cooler
fit the side panels and temp fit the scuttle to allow mounting of the header tank.
plumb in the engines cooling system and electronics
fit completed zx9r setup
have the car sent to my exhaust guy to have that fabricated
then....
START THE ENGINE
Craig
morcus
| posted on 2/10/09 at 01:48 PM |
Does anyone on here use there kit car in the winter months, winterised ot otherwise?
dan__wright
| posted on 2/10/09 at 02:58 PM |
ive got the following on my list:
finish rebuilding hubs / shafts
swap hubs and diff our for the 3.14
full cage + side bars
tidy up engine wiring + move ecu onto engine cradle
few over bits of wiring to tidy
improve coolant plumbing slightly.
FREE THE ROADSTER ONE…!!
prawnabie
| posted on 2/10/09 at 04:11 PM |
Ill be using mine when its not raining - don't mind cold but hate rain!
| posted on 2/10/09 at 07:26 PM |
Use mine all year round normally but this winter I'm stripping it to get the chassis shot blasted and painted due to rubbish powder coating.
Stuart_B
| posted on 3/10/09 at 05:54 AM |
i am taking the pinto out fitting a durtec, and chaning the diff, rear half shafts and rear brakes to disc.
