liam.mccaffrey
| posted on 5/10/09 at 08:08 PM |
OBD Fault codes-Volvo
After thinking all was well with the v70
I have the following fault codes
P0650 Malfunction Indicator Lamp (MIL) Control Circuit Malfunction
P0722 Output Speed Sensor No Signal
P1618 SBDS Interactive Codes
I am informed that the second 2 are the symptom of a dodgy trans output speed sensor and fairly easy to fix.
I have a feeling that there is no bulb behind the warning light!!
I'm never buying a car, even a banger without taking the fault code reader again.
Build Blog
Build Photo Album
owelly
| posted on 5/10/09 at 08:24 PM |
This may help. Or not...
http://www.v70r.com/forums/index.php?showtopic=12254
http://www.ppcmag.co.uk
blakep82
| posted on 6/10/09 at 12:30 AM |
my mum's car brings up every fault you can think of. including 'cruise control brake circuit malfunction'
it hasn't got cruise control.
not sure how much i trust it (the fault codes that is. well, and the car too...)
________________________
skodaman
| posted on 6/10/09 at 02:06 AM |
Maybe it's better if everything appears to work to just not use the fault code reader at all.
Skodaman
owelly
| posted on 6/10/09 at 08:31 AM |
My chum had the Vauxhaul dealer searching for many (costly) hours tracing OBD faults on his Vectra. A new battery sorted it! Every time the voltage
spiked undert a certain value, it would ping-up faults!
