omega0684
| posted on 7/10/09 at 01:36 PM |
where can i get these bolts
im after the bolt in this add, i have already bought the set but i need 3 that are 50mm long and not 40mm which are the ones on ebay, i have been to
my nut and bolt supplier and he doesn't do them
they are completed threaded bolts that have an allen key impression in the end of them, like i say i only need 3, M8 x 50mm.
Linky to ebay
i have e-mailed the seller to make him aware but he hasn't got back to me yet.
all help appreciated
cheers
Bluemoon
| posted on 7/10/09 at 01:40 PM |
You can't get a longer one and cut it down??
Nick Skidmore
| posted on 7/10/09 at 01:49 PM |
They are grub screws, albeit long ones, if you ask / search for them under that nae you may have more success.
andy350z
Try Balls Fasteners in Cheltenham
http://www.yell.com/b/Balls+Fasteners-Fixings+and+Fastenings-Cheltenham-GL519LT-4732858/index.html
[Edited on 7/10/09 by andy350z]
RAYLEE29
| posted on 7/10/09 at 01:51 PM |
cant you just use stainless studding and put a hacksaw across the end for a screwdriver slot if you really need it?
normally you just put two nuts on to wind them till they bottom out then remove the nuts.
or was there aparticular reason you needed them socket ended?
| posted on 7/10/09 at 01:55 PM |
Personally I'd get a long 12.9 bolt cut the head off and temporarily lock two half nuts together at the top of the threaded section to put the
spanner on to get it in then unlock the nuts and remove.
Happy days.
dave107
| posted on 7/10/09 at 01:57 PM |
Just phoned my nut and bolt man he has M8 x 50mm Stainless Steel Grub screws in stock.
He is in Sussex, but i'me sure he could post if they would ever get to you at mo.
Tel: 01243 5514 84.
omega0684
| posted on 7/10/09 at 02:03 PM |
cheers guys!
thefreak
| posted on 7/10/09 at 02:14 PM |
Also try Pugh & Sanders in Burton/Tamworth/Derby. They usually stock that sort of stuff
MikeR
| posted on 7/10/09 at 03:13 PM |
have you tried the screw place behind B&Q in coventry?
(trying to remember the name and can't at the moment).
Just make sure you get the old boy and mention its for a kit car. They used to do all the nut & bolts for caterham. You want to avoid the young
(30's) guy as he's an a*se & couldn't cope with the fact i was telling him how long a shank i wanted not the total bolt length.
He then couldn't understand why the old boy who figures out the prices charged me sod all after he'd spent 20 minutes finding bolts i
didn't want.
(old boy listened to the conversations and probably had his head in his hands listening in).
