Author: Subject: OT - Any strutural engineers on here today ?
mcerd1
posted on 7/10/09 at 06:07 PM Reply With Quote
I've got a bit of a problem with a structure I'm designing at work, basicaly I need to reduce the wind load on it....
Its only a tempery structure, but its going to up throught the winter so I can't save anything on the seasonality factors
I'm using BS6399-2 for the wind loads and thinking about using a lower probability factor (instead of the standard 50 year wind)
anyone got any experience in playing with these factors ?
any other suggestions ?
cheers
-Robert
Howlor
posted on 7/10/09 at 07:10 PM Reply With Quote
It'l be reet!
mcerd1
posted on 7/10/09 at 07:26 PM Reply With Quote
Originally posted by Howlor
It'l be reet!
not at 900 tonnes of concrete for a tempary structure it won't
rachaeljf
posted on 7/10/09 at 07:38 PM Reply With Quote
Annex D!
Read Annex D of 6399-2. It shows you how to derive different values of Sp for different return periods. If your structure will be up for only a year for instance, you can use Sp = 0.749 (see Note 1). Using this, your qs will be reduced by 0.749^2, i.e. about 50%, quite a handy reduction!
Cheers R
Guinness
posted on 7/10/09 at 08:37 PM Reply With Quote
What will it squash if it comes down?
A school? or some cows?
I'd be doing some risk analysis before taking out any strength from it.
Mike
mcerd1
posted on 8/10/09 at 08:04 AM Reply With Quote
Mike
Its a crane in our own yard for errecting another structure
the problem is that I've no experience of risk assesment
thats why the initial design was for 50 year wind (Q= 0.02, Sp= 1.0)
so where do I find guidance on acceptable risks ?
rachaeljf
posted on 8/10/09 at 08:49 PM Reply With Quote
Who is supplying the crane? They should do all that for you. Crane design is not quite the same as a normal structure, there are dynamic effects to take into account.
mcerd1
posted on 11/10/09 at 01:14 PM Reply With Quote
they arn't interested
rachaeljf
posted on 17/10/09 at 09:47 PM Reply With Quote
It sounds like you are buying/hiring a pillar crane or the like, and you have to design your own support structure for it, using some 375 cubic metres of concrete? I suggest you engage a structural engineer.
Cheers R
mcerd1
posted on 18/10/09 at 05:53 PM Reply With Quote
its a beam crane
rachaeljf
posted on 18/10/09 at 08:34 PM Reply With Quote
Well, give us some info on the crane and we might be able to help!
posted on 19/10/09 at 09:45 AM Reply With Quote
You can hire mobile cranes to lift up to 1300 tons nowadays. How much is the 900 ton block of concrete going to cost to get installed and removed if it's temporary ?
