| posted on 12/10/09 at 03:47 PM |
Cheap Mig Wire?
Just bought meself a new Mig that takes a 15kg coil
Anyone recommend a cheap place for wire?
big_wasa
| posted on 12/10/09 at 03:57 PM |
unless you plan on using lots get a 5kg or it will rust over winter and not weld very nice
MkII
| posted on 12/10/09 at 05:44 PM |
15 kg willnot rust if you take it out of machine and store it in house if not gonna be used for a while. try phoning T Proctor&son for wire they
have a branch at gateshead can getr you the no. if you need me to,I dont have it to hand as I use thier carlisle branch hth. m.
Mark Allanson
| posted on 12/10/09 at 07:00 PM |
A lot of DIY machines will take a 15kg reel, the wire feed systems are not up to the job. There is also a flywheel effect which can give over run
unless you tension the clutch correctly, which in turn puts more strain on the wire feed.
| posted on 12/10/09 at 07:07 PM |
^^ yepo - what MA said.
stick to littl'uns.
15 Kg .... are you welding on a dialy basis, that is a poo load!!
| posted on 12/10/09 at 07:10 PM |
Machine is a pro model and only accepts 15kg reels....
londonsean69
| posted on 12/10/09 at 07:21 PM |
Not necessarily.
Mine takes a 15kg spool because of the depth of the spindle - but if you stick a roll of gaffer tape behind it, it takes up 2" of slack and fits
perfectly.
I have a 15kg mild steel spool, and a 5kg stainless spool.
You can buy an adaptor - but I prefer the 5kg spool bodge
Sean
[Edited on 12/10/09 by londonsean69]
| posted on 12/10/09 at 09:23 PM |
Cheers Sean, mine is a Portamig 185 and the adapter was about £14 which I didn't buy
| posted on 13/10/09 at 07:25 PM |
i find 5kgs to be too big myself, will never finish it. 15kgs would be a nightmare! Taking it into the house to stop it rusting sounds like a right
pain in the neck! Sods law as soon as you wound it up you realise you wanted to weld something else...
