NigeEss
| posted on 29/10/09 at 11:18 PM |
30amp supply, is it really needed ?
Following the demise of my 20 odd year old 120amp welder I've now bought a
150A jobbie. The salesman in Machinemart said I need a 30A supply. The
mains cable on it is no thicker than my kettle so is 30A really needed ?
dogwood
| posted on 29/10/09 at 11:31 PM |
I bloody hope not....
I think it's unlightly, even then only if you are using it at full power
FREE THE ROADSTER ONE…!!
dogwood
I say that because I just bought one myself...
[Edited on 29/10/09 by dogwood]
daviep
| posted on 29/10/09 at 11:42 PM |
I regularly run my 180A mig at full power on a 13A supply.
Regards
Davie
iank
| posted on 29/10/09 at 11:53 PM |
150 Amp welder theoretically needs a 16A supply for full power. Though many people get away with a 13A plug (be prepared to change the fuse every now
and then).
Anonymous
dogwood
| posted on 30/10/09 at 12:08 AM |
Be prepared to change the fuse every now and then).
Fuze ??????????????????
Oh you mean a 6mm bolt......
blakep82
| posted on 30/10/09 at 12:24 AM |
i think he meant 16A
anyway, it'll work on a 13a fuse, but on full power mine blew fuses. maybe thats because i was trying to weld axle tubes *, i don't know,
but yeah, it'll be fine on a 13a plug
anyway, i put a 16a circuit in my garage, along with a proper blue plug
* i did give them to someone else with a much bigger welder to do them. a guy at the MoD submarine base in fact, he also xrayed them to check they
were welded properly
[Edited on 30/10/09 by blakep82]
________________________
James
| posted on 30/10/09 at 12:46 AM |
My 150amp SIP was fine on 13A.
It managed a fully welded in floor fine too.
James
- Muhammad Ali
mad4x4
| posted on 30/10/09 at 07:13 AM |
Mine protamig 180 worked for about a year on a 13Amp plug. Eventually chanegd it to 16 A as the cable was a bit short to go to the 13amp
socket.....
No - Probs with either
Scot's do it better in Kilts.
| posted on 30/10/09 at 09:19 AM |
the circuit breaker - the thing that is under the stairs - trips.
I plug into the cooker sicket - 60 A and no probes ever.
chance are it won't draw 16 A continuously but in bursts - and hte burst will trip the breaker - won;t melt the cable though.
I bought 16 A caravan cable off ebay - approx £ 13 and use that for the welder .
if you use extension , never have it wound up but lying loose and loopy.
| posted on 30/10/09 at 10:15 AM |
Most ring mains are rated to 32 amps, more than enough for a welder. Poroblem is the puny 13 amp plug is not up to delivery much more than 13 amps and
as it gets hot that goes down.
I bought a 16amp commando socket and plug (from Toolstation for a fiver) and have my Portamig plugged into that.
Whereas my old arc welder used to make the lights flicker in the house the now (more powerful) Portamig doesn't.
dhutch
| posted on 30/10/09 at 10:26 AM |
Yeah, i shouldn't need a 30amp take off.
- However as said, they will tend to blow a 13amp fuse fairly readily, hence they tend to get wrapped in tin foil or similar. Very bad practice
indeed, but sadly common non the less.
If you where doing a lot of welding i personally would certainly thing about fitting a 16amp take off (or even a 32amp takeoff) to the garage.
- The ring main will be fused at 30/32amp so the 13amp limit is only the plug/socket.
We had these all round the workshop at school years back, but you could do similar with a 16amp socket.
http://www.screwfix.com/prods/10398/Electrical-Supplies/Weatherproof/Weatherproof-IP66/56-Series-IP66-13A-1G-RCD-Skt
Daniel
