<<  1    2  >>
Author: Subject: Increase the speed limit
omega0684
posted on 29/10/09 at 11:39 PM Reply With Quote
Apparently in Utah they put the speed limits up for a study & they found that there was no increase in incident rate.
full report HERE
Maybe we should e-mail this to the transport minister and the speed authorities!
blakep82
posted on 29/10/09 at 11:42 PM Reply With Quote
of course there wasn't. even look at german autobahns. if they're safe enough for the germans...
it would also reduce congestion too. cars would all spend less time on the road job done
________________________
MautoK
posted on 29/10/09 at 11:57 PM Reply With Quote
Utah has 27 people per sq mile and outside SLC it's probably about 5. Probably only see another car every other week!
England has over 1000 per sq mile
owelly
posted on 30/10/09 at 12:28 AM Reply With Quote
You lot are sooooooo September 2009...
I've just driven up the M1 and I can safely say that the motorway speed limit for the UK is well over 100mph. I was doing (around) 70mph with two rows of cars in the outer two lanes travelling a feck site faster!!!
Obviously October 2009 is the new speed limit month.
http://www.ppcmag.co.uk
blakep82
posted on 30/10/09 at 01:47 AM Reply With Quote
lol if the speed limit was put to 100mph, we'd all still be doing 110
Macbeast
posted on 30/10/09 at 02:17 AM Reply With Quote
The tree-huggers would object to the increased emissions and carbon tyreprint.
A1
posted on 30/10/09 at 03:34 AM Reply With Quote
the tree huggers are just ignorant fools... differant engines have differant economic speeds.
100mph on the motorway sounds good. the inside lanes can be for the hippies.
Richard Quinn
posted on 30/10/09 at 05:56 AM Reply With Quote
Slightly OT but I did find it both interesting and amusing - I was reading an industry digest yesterday which said that although used 4x4 ownership in the UK was down, sales of used 4x4s has actually increased as more and more traders are now exporting. This is mainly due to large UK stocks (caused by stigma, taxation and fuel costs) and the weak pound. A great victory for the tree huggers! - emissions obviously aren't such an issue if you end up moving them to a different part of the same bl**dy planet!
speedyxjs
posted on 30/10/09 at 07:04 AM Reply With Quote
I dont think i would on parts of the M25. When i was in germany, i was doing 115 on a concrete section (like part of the 25) and the back end was all over the place
mad4x4
posted on 30/10/09 at 07:11 AM Reply With Quote
Problem is people in this country don;t know how to drive ont he Motorway / Dual Carriage way.
Every night I travel home and find people sitting in the fast lane at 50-55 Mph leaving the Slow lane empty
Scot's do it better in Kilts.
Richard Quinn
posted on 30/10/09 at 07:34 AM Reply With Quote
That's because there is no incentive to move over. On the autobahn, an A8 doing 150mph and getting larger in your mirror encourages you to change back fairly quickly. At certain times they also restrict HGVs to the inside lane only (which is nice!)
smart51
posted on 30/10/09 at 08:05 AM Reply With Quote
The Germans are far better drivers than us by all reports. They have better lane discipline. They don't tailgate so much and they get out of the way if a faster car is behind them.
Higher speeds reduce the capacity of roads to carry large volumes of cars. Studies show that the largest number of cars per hour a road can carry is 20 MPH and it gets steadily worse the faster you go.
Accident rates in Utah were probably not affected by the speed limit change as it is one of the most empty US states. Here, motorway traffic has such a bad tailgating habit that 70 MPH can't really be justified. Increasing the limit may not lead to more collisions but there will certainly be more cars involved each time there is a crash.
There would need to be a big increase in the standard of driving here before an 80 MPH limit could be introduced.
smart51
posted on 30/10/09 at 08:07 AM Reply With Quote
Other than courtesy, good manners, driving skill and respect for others?
smart51
posted on 30/10/09 at 08:19 AM Reply With Quote
True but irrelevant. Mostly, petrol engines are at their most efficient at an RPM a little lower than peak torque with a throttle opening of around 70%. Diesels are a bit different. What has that got to do with road speed?
A car's demand for power goes up with speed. 1 MPH faster = more power required. Engine load and gearing ratios mean that there is a peak in efficiency which can be as low as 20 MPH in small diesels but is often more like 30 or 40 MPH depending on your car's aerodynamics and gear ratios. Nobody's car is more efficient at 100 MPH than at 70. It can't be done.
speedyxjs
posted on 30/10/09 at 08:26 AM Reply With Quote
Il second that. They also only use the fast lane for overtaking. As soon as they are past they pull in until they catch the next car. Same as the french.
speedyxjs
posted on 30/10/09 at 08:30 AM Reply With Quote
My tintop is more efficient at 80 than it is at 70 which i find a bit strange. Iv calculated it loads of times as i didnt beleive it. Average about 28mpg at 70 and 34 at 80.
posted on 30/10/09 at 08:35 AM Reply With Quote
Better lane discipline applies to most of the continent to be honest, but you do tend to get more utter bellends making ridiculous manoeuvres at high speed IME, e.g. cutting across two lanes of trafic to make the exit causing a sea of brake lights and soiled underwear.
Also tailgating at 100+mph is pretty stupid when it's clear the car(s) in front are blocked, but this is absolutely commonplace.
posted on 30/10/09 at 08:52 AM Reply With Quote
Isn't that the same as more collisions ?
posted on 30/10/09 at 08:59 AM Reply With Quote
I agree that our motorway driving standards here are appalling !
I have literally driven the length and breadth of continental Europe and it's a breeze... the minute you get back in Blighty it's snarl-ups for no apparent reason and the majority of cars all wanting to be in the offside lanes, but unable to make progress because they can't organize themselves!
Net result... we all end up going at 50mph!
As said before, the greatest incentive in Germany for getting out of the way on the unrestricted Autobahns is seeing a fast Audi, BMW or Merc cruise ship bearing down at you at warp speed 10 and flashing it's xenons at you
They're not shy at flashing you out of the way too!
It's Evolution Baby!
posted on 30/10/09 at 09:24 AM Reply With Quote
we get that her from white van drivers and it is inevitably in situations where there is a queue in traffic in front of you so what do they gain? nothing.
what do you loose? bieng force to make unnecessary lane change and lane changing probalby is the cause of a lot of accidents.
posted on 30/10/09 at 09:26 AM Reply With Quote
although the emissions may increase, the journey time and henceforth the time the increased emissions are emitted decreases.
posted on 30/10/09 at 09:31 AM Reply With Quote
What the bloody hell is that song in your signature???
posted on 30/10/09 at 09:32 AM Reply With Quote
Ah, 'Release the Bats' by The Birthday Party!
Richard Quinn
posted on 30/10/09 at 09:58 AM Reply With Quote
Traits that have pretty much disappeared within the UK (not just related to driving either!!)
smart51
posted on 30/10/09 at 10:07 AM Reply With Quote
Eh? Emissions PER MILE increase. Time is irrelevant.
<<  1    2  >>
