blakep82
| posted on 30/10/09 at 06:14 PM |
carbon kevlar diff covers
how hard would it be to make a carbon/kevlar atlas diff cover? i've got a new pressed steel one.
could you easily make one straight from the steel one, or would you need to make a mould from the steel one to then make a carbon one?
if taken straight from the steel one, should it be done on the inside or outside?
________________________
clairetoo
| posted on 30/10/09 at 06:20 PM |
I'd make a mold off the outside of the cover , then make a cover from the mold , and make it faily thick around the edge so as to stop
distortion around the bolts .
Damn that would look cool
Its cuz I is blond , innit
Claire xx
Will weld for food......
blakep82
| posted on 30/10/09 at 06:22 PM |
was thinking they'd look cool myself
seeing as my axle can just about be seen on my car.
any tips on the best material for making a mold?
fibreglass? expanding foam and filler?
if i do it, i might make a few
also trying to work out some bonnet pin covers. probably just fibreglass
omega0684
| posted on 30/10/09 at 06:24 PM |
claire do you fancy trying it out on my lsd cover the diff will be out tomorrow lol
clairetoo
| posted on 30/10/09 at 06:39 PM |
I'll have a go - but tomorrow I will getting mucky underneath an Alfa that just failed it's MOT
Claire xx
clairetoo
| posted on 30/10/09 at 06:42 PM |
Make the mold from fibreglass so you can get a good polish on it , the only tricky bit is getting a good finish on the edge of the carbon/kevlar (it
wont sand as the kevlar just goes fluffy )
Claire xx
blakep82
| posted on 30/10/09 at 07:04 PM |
ooh, i know it goes fluffy my bodywork is made of kevlar repairs are a nightmare
thinking thin cutting disc in the grinder will be the best option. though not ideal.
cool. i was about to start drilling and welding a breather into my steel cover, but i'll hold off that for a little while.
what sort of thickness should i aim for?
blakep82
| posted on 30/10/09 at 07:29 PM |
would probably benefit from some of these so it doesn't crack under the bolts too
Liam
| posted on 30/10/09 at 08:42 PM |
You could try and make sides to the mold and lay the carbon up around the sides rather than as just a flat slab to avoid the rough looking edges.
