SeaBass
| posted on 4/11/09 at 04:18 PM |
OT : Heating Programmer Experts Wanted
I'm fed up with looking into a dark cupboard to see a tiny LCD programmer that I can't read so I was thinking about changing it.
I thought it might be good to change it to wireless and mount the transmitter on the kitchen wall about five meters away as a room stat.
I was looking at Honeywell and Siemens units but have a problem: I can't find a 7 day wireless programmer/stat which will control both my boiler
and the (one) motorised valve for the hot water ie a 2 channel unit.
Anyone had this issue?
adam1985
| posted on 4/11/09 at 04:30 PM |
dont think you can get a 2 channel wireless stat
big-vee-twin
| posted on 4/11/09 at 04:36 PM |
I replaced my thermostat with a programmable one which has time and temperature settings for each day, I just leave my controller permenantly on now
and let the programable thermostat do the job simple to fit and its now located on the wall in the hall.
This will achieve the same thing see screw fix
Link
http://www.triangleltd.com
SeaBass
| posted on 4/11/09 at 04:55 PM |
Big Vee, sounds great but I need mine to control the hot water too the one in your link is only for the heating and it's not wireless.
Out of interest though how did you manage to install a wired unit in the hall away from the boiler?
[Edited on 4/11/09 by SeaBass]
t16turbotone
| posted on 4/11/09 at 05:05 PM |
what you would normally do is to leave exisisting programmer to control DHW alone. Then purchase a RF programable room stat for your heating,
SeaBass
| posted on 4/11/09 at 05:14 PM |
How do you wire it so that both units are able to switch on the boiler then?
Not sure my OCD would cope with that solution either.
t16turbotone
| posted on 4/11/09 at 05:22 PM |
ocd...?
SeaBass
| posted on 4/11/09 at 05:46 PM |
Obsessive Compulsive Disorder
| posted on 4/11/09 at 06:22 PM |
I'm using nice Salus units with fancy blue backlights. They do a HW/CH unit and it's 7 day programmable.
I'm using two of their single channel programmable thermostats for the underfloor heating and main heating in my new house.
| posted on 4/11/09 at 06:24 PM |
It's not RF but hey....
adam1985
| posted on 4/11/09 at 07:09 PM |
salus do rf stats and progs but none are 2 channel
big-vee-twin
| posted on 4/11/09 at 08:22 PM |
Hi Again, you leave the Heating side of the controller permanently switched on-you leave the Hot water side as it was -switching on and off.
You replace your existing wall mounted thermostat with the one I linked to, connecting the existing thermostat wires to it.
You program the thermostat Sunday through to Saturday with 6 time programs and temperatures through the day.
Your heating controller is then on a wall where your thermostat used to be takes about 30 mins to do.
The programmable thermostat turns the boiler heating mode on off through the day.
[Edited on 4/11/09 by big-vee-twin]
| posted on 4/11/09 at 10:32 PM |
i am condused. how often do you need to mess with the timer?
and you've not got a torch?
much cheapness.
SeaBass
| posted on 5/11/09 at 11:12 AM |
much cheapness.
Quite a bit as the Winter draws in to cut my energy bills.
I also wanted to add the thermostat functionality which we don't have. It just churns out heat at a specified boiler temperature for a set
amount of time. This costs extra money!
