Author: Subject: Any Ideas whats Wrong ? (Scooter)
ditchlewis
posted on 18/11/09 at 09:49 PM Reply With Quote
Well it was "Locost" We purchased a 50cc Jinlun scooter for one of the lads (I know that they are a Pile of steaming brown stuff). it has now done 3000 miles and it has stopped working...
last week ed was coming home and it stuttered briefly but continued to run. A couple of days later it once again stuttered and then would not pull at all. he got a lift home and i went back with him. it fired up but shuttered and would not pull. after a check over of all cables for water ingress it fired up and pulled but appeared to be misfiring.
looked at it on sunday and it ran well but all of a sudden just stopped. when it runs it runs well (Sweet).
there is fuel.
there apears to be a spark.
I've already replaced the Coil and checked the carb for dirt in the jets.
tonight it would not even start.
possibilities ?
the ignition box?
alternator?
timing?
getting p~~~~d off with it now as you can only get parts online and nobody will work on them.
ditch
Steve G
posted on 18/11/09 at 09:57 PM Reply With Quote
Water in the fuel?
skodaman
posted on 18/11/09 at 09:58 PM Reply With Quote
Could be timing or something electrical, or water in fuel/carb float bowl. If it's two-stroke make sure you've got oil in it and if autolube check the pump is giving right amount. If two-stroke first thing I'd try is a new spark plug. They're very prone to fouling plugs particularly in the hands of teenagers.
Of course the real reason why it won't work properly is it's Chinese and probably never has worked properly.
Skodaman
ditchlewis
posted on 18/11/09 at 10:05 PM Reply With Quote
it's a 4 stroke. i though about fuel but he always buys fuel at the same place for over a year now.
i took the plug out and it was wet, as i had been turning it over for a while. when dry it looked clean and i better nick than the ones in the indy
i'm getting to realise that it was cheap for a reason
electrical seams the most likley problem, only when i have got it running it has been using full throttle settings.
ditch
tomprescott
posted on 18/11/09 at 10:12 PM Reply With Quote
Try using a blow torch on the spark plugs for 30secs to a min then get them back in as quickly as possible and see if it starts, if it does then its likely ingress of water!
busakid
posted on 18/11/09 at 10:14 PM Reply With Quote
scooter
i looked at a yiben scooter four stroke it would not run and playing up and the tappets where tight ,its run fine ever since and thats 6 months ago
ditchlewis
posted on 18/11/09 at 10:16 PM Reply With Quote
Will give the plugs a go.
also will check the valve spacing to ensure that they are opening.
ditch
dlatch
posted on 18/11/09 at 10:34 PM Reply With Quote
change spark plug and poss CDI
big-vee-twin
posted on 18/11/09 at 10:50 PM Reply With Quote
You need to visist the Chinese bike forum link lots of info on there.
However I would suggest water ingress into the alternator casing it is quite common.
Also Chinese bikes tend to have counterfit spark plugs fitted - yes counterfit and they are Sh*t
They also have poor electircal connections you should have a look over the wiring.
http://www.triangleltd.com
posted on 18/11/09 at 11:08 PM Reply With Quote
My nephew has one and I had to sort the carb on it to get it running, they are crap but if a decent Mikuni was available the rest of the engine seemed fine.
skodaman
posted on 19/11/09 at 03:19 AM Reply With Quote
If it just stops suddenly rather than dying gradually then it sounds electrical rather than carb related.
Just a thought but try new plug cap. My beloved Honda CB250RSA= single cylinder four-stroke only ever refused to start once in 50,000 miles and eleven years and that turned out to be the plug cap which was an NGK one which is normally quality stuff.
If it's usually been left outside it could be damp anywhere in electrics though.
Skodaman
ditchlewis
posted on 19/11/09 at 08:13 AM Reply With Quote
Many thanks, the scooter is normally left out side and i was leaning towards water in the electrics. have ordered new CDI and already relaced the coil, HT lead and plug cap.
the carbs are duff and i may have now ruined it late last night i may have over tightened the idle jet i'm reluctant to buy another is there any way to fix. Moral dont work on delicate things when you are angry and tired
Peteff did you fit another make of carb? if so what make and model.
Ditch
[Edited on 19/11/09 by ditchlewis]
