Author: Subject: Anyone done their own block paving?
James
posted on 20/11/09 at 06:55 PM Reply With Quote
There's no parking around here at all so we've been parking on the lawn!
Unsuprisingly this looks a total mess so we're thinking of block paving it.
I know there's planning issues for this but aside of them, has anyone done the work themselves?
The only issues I see is that the house is a little lower than the pavement (approx 200mm) so the drive will have to slope to the house. I was thinking of having a 1m wide flowerbed in front of the house to collect rain run-off.
There are no man-holes or anything to complicate matters.
The kerb is already lowered to no worries there either.
My main worry is getting the slope down from the pavement to the house (200mm drop) straight/level.
Any thoughts?
James
richardR1
posted on 20/11/09 at 07:16 PM Reply With Quote
Done a lot of block paving at work. It is fairly straightforward to do, it's all in the preparation. You need to dig out to allow for 150mm of crushed topping which needs compacting down thoroughly with a decent size vibrating plate. On top of this you want a few inches of sharp sand also compacted. The easiest way of getting a nice straight fall is to get a length of timber long enough to go from the pavement to the house and use this to screed the sand to get a perfectly even slope. This is the part that takes the time but gives a good result. You can screed a section then lay the blocks, then screed a bit further etc. Lay the blocks nice and tight and then at the end brush kiln dried sand into the joints, run over with the vibrating plate then re-sand. Stihl saw is the best bet for any cuts you need to do as block splitters don't tend to do a very neat job. Regarding drainage you can get plastic gulley that comes in sections with plastic grate that goes over the top and this is designed to be driven on. Just run that along near the house front and run it into your rainwater drain.
Most firms round here charge around £45 per square metre for the complete job. You will be looking at about £10 per sq metre for standard 50mm block paving.
MK Owners Club Member 1015
hillbillyracer
posted on 20/11/09 at 08:05 PM Reply With Quote
You should take a look at senciled concrete, you can get colours, patterns & finishes to look like all kinds of paving but less of the hassles of getting it all level etc as it's just concrete with a nice finish, no gaps for the weeds etc & the bits that get most weight/traffic wont sink as it'll be all one lump.
Like this:
http://www.patternconcrete.co.uk/vGallery.aspx?ID=52
fesycresy
posted on 20/11/09 at 08:46 PM Reply With Quote
This was posted on here recently.
Link
Very good link, loads of info.
carpmart
posted on 20/11/09 at 08:54 PM Reply With Quote
Like this:
That looks really good. Some of the pics look a little like the Duckworths outside wall on Corrie but in the main, I like that!
Is it durable?
Anyone any experience with this concrete?
'94 MX5 MK1, 1.8
F10 M5 - 600bhp Daily Hack
Mercedes A class - Son's Car
mangogrooveworkshop
posted on 20/11/09 at 09:18 PM Reply With Quote
yes
[Edited on 20-11-09 by mangogrooveworkshop]
posted on 21/11/09 at 09:07 AM Reply With Quote
You need to find out what the local authority in your area will allow --- I suspect these days they will require permeable paving and your are likely to require planning permision.
Because of the reverse slope of the driveway this might be best anyway. My drive way has a similar slope and although it has a permeable surface one of the first things I did whe I moved in was put in a surface water drain.
You might want to consider using those blocks used by local authorities in overflow car parks that have holes for grass or gravel.
swanny
posted on 21/11/09 at 09:52 AM Reply With Quote
we've nopt long had ours done and when speaking to planning they basically said you dont need planning so long as none of your water from your drive goes into the drains (ie must soak away) permeable (?) paving is a good solution or if you like you could just build in a number of run off areas as we have done.
would be a bit concerned thought ab0ut having all the water rinning into a soak away next to your house. i thought they were meant to be five metres away for good reason? a lot of water comes of a decent sizded drive in a downpour, whereas at the minute most of this will be soaking into the lawn. in your case i'd feel happierr with permeable
smart51
posted on 21/11/09 at 10:01 AM Reply With Quote
Is it durable?
One of my neighbours has this and the people next door have blocked paving. Both put down at the same time. The blocked paving looks nicer as the concrete is a little bit shiney and plastic but the block paving has sunk a bit where the concrete looks like new.
Grimsdale
posted on 21/11/09 at 10:47 AM Reply With Quote
i'd advise only using an inch of sand, it's only there to even out the lumps in the hardcore you put down, any more and you risk it sagging.
andkilde
posted on 21/11/09 at 03:13 PM Reply With Quote
I'll second the thin layer of sand, also use as deep a layer of well-compacted crushed stone beneath as you can afford, 6" to 8", more if possible. And be sure to brush fresh sand across it every few months to replace the stuff that the rain carries away.
My back aches just thinking about it though -- you'll spend what you save doing it yourself on chiropractor bills
Cheers, Ted
