Author: Subject: Workbench Top Recommendations
bigbravedave
posted on 25/11/09 at 11:23 AM Reply With Quote
Not long moved into a new house and more importantly new garage! As funds are somewhat tight Im just knocking up a quick workbench out of industrial dexion racking (before the wallpapering table karks it!) to see me through until I can find the time and funds to mig up a bench in meaty box section. What do people recommend as a material for the work top, it’s about 8ft by 2ft, and I will end up using it on the final bench.
Bluemoon
posted on 25/11/09 at 11:46 AM Reply With Quote
Kitchen work top (might find on in a skip if your lucky)..
[Edited on 25/11/09 by Bluemoon]
hughpinder
posted on 25/11/09 at 11:50 AM Reply With Quote
Sheet of 3/4" ply, cut lengthways and use both layers!
Hugh
twybrow
posted on 25/11/09 at 12:13 PM Reply With Quote
A 2nd vote for kitchen worktop. Got mine for free, and it works a treat!
Ask B&Q for any offcuts they have floating around, or look on Freecycle....
mr henderson
posted on 25/11/09 at 12:31 PM Reply With Quote
If you want a 'hard' surface then kitchen worktop is good. If you are going to be doing any hammer work on it you might be better off with mdf. I personally prefer mdf for a car-related workbench.
In either case, getting two pieces and fixing them back to back is good, increase the weight and helps to keep them flat if you get the natural curves that most sheet materials have to oppose each other
wilkingj
posted on 25/11/09 at 12:34 PM Reply With Quote
Or a wooden top or kitched worktop, with a thin sheet of steel on top.
Best Regards
Geoff
http://www.v8viento.co.uk
speedyxjs
posted on 25/11/09 at 12:39 PM Reply With Quote
I used the ex dining room table until i broke it
craig1410
posted on 25/11/09 at 01:03 PM Reply With Quote
I used four 6"x2" structural joists lengthways side by side (24" deep worktop) and then a piece of MDF on top to provide the surface. I think I might add a steel surface on top of that to make it a bit more durable. My frame is also made from a combination of 6x2 and 4x2 beams tied together with triangulation etc.
Very heavy and very strong!
tegwin
posted on 25/11/09 at 01:40 PM Reply With Quote
Get a thin piece of hardboard or steel on top of whatever you decide upon... that way once its covered in oil, paint, cack and full of holes you can bin it and start again
www.verticalhorizonsmedia.tv
designer
posted on 25/11/09 at 06:01 PM Reply With Quote
I prefer to use a cheap firedoor. It's thick and solid, and cheaper than a worktop.
Then cover with hardboard for a working surface.
iscmatt
Contributor
Posts 1929
Registered 30/3/06
Location York
Member Is Offline
Photo Archive Go!
Building: - BUILT - 2.0 pinto indy, Kent Cam, zzr1100 carbs
posted on 25/11/09 at 07:02 PM Reply With Quote
Another vote for kitchen worktop, we redid our kitchen recently and so i got mine for free.
