Author: Subject: Sky in a caravan
jacko
posted on 28/11/09 at 07:21 PM Reply With Quote
Sky in a caravan
Hi All for my sin's i have a c/van and with analog tv going i have been thinking of getting a old sky box and dish + use my card out of the house
Can anyone see a problem doing this,
+ Some time ago in aldi [i think ] they had a set up for sky anyone got this is it any good ?
Graham
prawnabie
posted on 28/11/09 at 07:22 PM Reply With Quote
http://www.maplin.co.uk/Module.aspx?ModuleNo=48737
ashg
posted on 28/11/09 at 07:25 PM Reply With Quote
i have got a dish and a spare box if you want to offer me a couple of pennies.
all you have to do is mount the dish on a pole/tripod and move it round until you get a signal
Haynes Roadster (Finished)
Exocet (Finished & Sold)
New Project (Started)
dogwood
posted on 28/11/09 at 07:26 PM Reply With Quote
Absolutely no problem at all.
I always take my Sky box on my holls to the south of France to watch my fav programs
I do use a slightly larger dish that far South though
FREE THE ROADSTER ONE…!!
billy
posted on 28/11/09 at 07:36 PM Reply With Quote
Cheapest way to get SKY into your caravan is get a tin opener and cut a big hole in the roof! bingo free sky
luego-lo-cost finished,vauxhall 16v 2.0,twin 45s de-dion rear set up
lsdweb
posted on 28/11/09 at 07:43 PM Reply With Quote
I took a dish and freesat receiver to the west coast of France this year and it was excellent! The easiest way of setting it up is to copy the alignment of somebody who has theirs working already!
Benzine
Go to Skye in a caravan and take books
amalyos
posted on 28/11/09 at 07:48 PM Reply With Quote
if you have a second box without multiroom, you'll only get the basic Sky packages (Sky1, Discovery etc) if you swap the card over, as the card is coded to the box.
i.e. you won't get Sky movies and Sports.
Only way to get everything is to take the matched Box and Card together.
The Aldi set up isn't Sky, it just gets you the basic freeview channels (or loads of German channels if thats what your into), although with better reception than an aerial.
[Edited on 28/11/09 by amalyos]
http://stevembuild.blogspot.com
jacko
posted on 28/11/09 at 07:50 PM Reply With Quote
Hi Mate thankyou for the offer but you live a bit to far away to get it
I will have a look around the Hull area for one Graham
rayward
posted on 28/11/09 at 07:54 PM Reply With Quote
be careful,
the new card are paired to the sky box, so won;t work with any other box ,
we have a main sky and multiroom, and can;t even swap cards between boxes
hth
ray
dogwood
posted on 28/11/09 at 07:58 PM Reply With Quote
Originally posted by rayward
be careful,
hth
ray
Not exactly sure if that is correct.
I don't have sky films or sport.
but got all the other channels.
the card works in both my boxes
Bluemoon
posted on 28/11/09 at 08:11 PM Reply With Quote
Most people use seem to use free stat in there vans
Dan
fazerruss
posted on 28/11/09 at 08:17 PM Reply With Quote
I used to take my sky+ system in the caravan. Just use the on board signal level meter on the box to find a good signal. It would be worth you getting a compass with directions marked on for the satalites, makes it a lot easier to set up when you know roughly which direction to point the dish.
"if assholes could fly this place would be an airport"
iank
posted on 28/11/09 at 09:08 PM Reply With Quote
Lots of (English) vans had sky on the site in France I was at. Those without motorised dishes seemed to spend a good 30mins on average getting a picture each night.
Waste of good red-wine drinking time IMO.
Anonymous
owelly
posted on 28/11/09 at 11:22 PM Reply With Quote
I bought a 12v Freeview box off Ebay and it works OK in the house but I havn't tried it in the Bongo Bus yet. It came with a little stumpy mag mount aerial. Would this be ok for use in a caravan? It only cost £20 IIRC so if it can get all the freeview stuff, like it sdoes indoors, then it may be a cheaper easier way to watch telly....
http://www.ppcmag.co.uk
splitrivet
posted on 29/11/09 at 12:17 AM Reply With Quote
Get a freesat box they aint much nowadays, sky boxes and cards are paired.
You'll get less channels than Freeview or freesat if you just use a Sky box without a card.
There used to be a free to air card for a skybox they were about a tenner but I dont know if they are still supplied, they need the number under your Skybox to pair the card.
Bob
Edit. Free to air cards are still available £20 by the time you factor in a s/h skybox you might as well have a new freesat box for £40 odd squids.
[Edited on 29/11/09 by splitrivet]
posted on 29/11/09 at 11:32 AM Reply With Quote
Freesat and Freeview satellite are not the same thing I found out. Freesat has an 8 day programme guide and freeview satellite only shows now and next. I recently put a freeview box in at home and found dishpointer and a compass to be the easiest way to locate a satellite. Put your location and choose which sats you want. I am on Astra 2D and Eurobird 1 and it picks them both up as they are very close together. A terrestrial box will only work if you have a clear line of sight to the transmitter, any hills, trees or buildings will cut your signal.
