Author: Subject: Q for any MOT testers......Emissions limits
NigeEss
posted on 6/12/09 at 10:38 AM Reply With Quote
What would be the emission limits for an imported Mitsubishi FTO, 2.0 V6 ?
DVLA has it logged as first used 31/12/95 and first registered 8/4/02.
Place I took it to says <0.2 but it's owner (not me) is disputing and also claims it's
exempt from cat test. Tested at 0.6.
Can't ask my MOT man as it's Sunday and he's away for the next few days.
stevec
posted on 6/12/09 at 10:47 AM Reply With Quote
I think almost everything after 1993 needs a cat, so would also have a cat test.
maximill666
posted on 6/12/09 at 10:50 AM Reply With Quote
First used or registered after August 1995, then its subject to a CAT test
Grimsdale
posted on 6/12/09 at 10:56 AM Reply With Quote
there is an exemption for imported cars built after the introduction of cats but not designed to pass the cat tests, check v5.
gingerprince
posted on 6/12/09 at 11:09 AM Reply With Quote
You're out of luck. I used to have an FTO on an M plate, and got away with <3.5. Since yours is late 1995 and therefore N plate, no dice.
See details on my website that I did years ago but are still valid I assume: -
http://www.stuffandting.com/cars/fto/service
bi22le
posted on 6/12/09 at 11:41 AM Reply With Quote
same as above. My brother had a fto and had to keep the cat in. It was on a p if i recall correctly. If had a full stainless system with a cat bypass included. He just swapped the two every time. It made a noise difference but not that much else. Keep the cat in and save the world!
Please read my ring story:
boggle
posted on 6/12/09 at 12:30 PM Reply With Quote
anything after k plate needs a cat....
however.....if the mot tester hasnt done the test within the 45mins then he cant fail it......keep the tester talking....for 45 mins!!!!
or find a 'nice' mot tester
boggle
posted on 6/12/09 at 12:33 PM Reply With Quote
you may also find even with a cat in it will read high, as the lambda may be on its way out....
NigeEss
posted on 6/12/09 at 12:44 PM Reply With Quote
First thing I did after it's fail was replace the lambda. Made no difference.
posted on 6/12/09 at 01:58 PM Reply With Quote
In the case of an import this isn't always true. If the car has no UK equivalent, and therefore no entry in the database it's tested to pre-cat limits if it is registered in 1995 or before. My L plate MR2 turbo fell under these rules (since the Turbo version was never sold in the UK).
posted on 6/12/09 at 02:29 PM Reply With Quote
Have had this before with an import, get in touch with your local V.O.S.A. office for the correct details
