smart51
| posted on 14/12/09 at 07:23 PM |
SD card problems
I've just bought an SD card of eBay - brand new and still in the packet. It doesn't work with either my PC or my camera (my old SD card
does). Before I complain that I've been sold a duff, Have I missed something or been a bit silly? Are they all supposed to work with any
drive? The new one is marked Lexar Multi-use 4GB SDHC.
splitrivet
| posted on 14/12/09 at 07:27 PM |
A sdhc card wont work in a sd slot sounds like youve bought the wrong card.
Bob
You need to take it out the packet first. That might help
tomprescott
| posted on 14/12/09 at 07:32 PM |
The HC suffix denotes high capacity, which may be why you are having problems with it, especially if your camera or pc card reader are old. Almost all
expandable memory ports have a limit as to the memory they can read, while an sdhc card should work with an sd slot, if your slot has an upper limit
of say a gig, and your card is 4gig, it won't read properly!
locoboy
| posted on 14/12/09 at 08:03 PM |
Some equipment will only work with certain versions of a memory card ie up to version 4 for example, if yours is a newer version ie 7 then it wont be
compatible.
I had the same thing with an old compact digital camera.
Locoboy
smart51
| posted on 14/12/09 at 08:40 PM |
Anyone want to buy a 4 gig SDHC memory card? Almost new.
mark chandler
| posted on 14/12/09 at 10:16 PM |
Buy a HD SD USB card reader off ebay I paid 75p for one last week, just waiting for it to arrive.
turbodisplay
| posted on 14/12/09 at 11:00 PM |
The problem is the fat16 format only supports 2gb, so you need fat32.
Your camera may not support fat32, but your pc should.
Darren
iank
| posted on 14/12/09 at 11:21 PM |
Darren
It's more than just that, see the compatibility problem of 4G and greater cards here
http://en.wikipedia.org/wiki/Secure_Digital_card#Compatibility_issues_with_4_GB_and_larger_cards
Anonymous
dhutch
| posted on 15/12/09 at 12:25 AM |
Yep, as said, there are compatabilty issues with sd cards.
- Fortunatly my camera supports SDHC but when i bought my current 8gb card i did need a new card reader.
Daniel
| posted on 15/12/09 at 08:05 AM |
Poundland has them for err a pound I keep a few handy to give to clients.
mcerd1
| posted on 15/12/09 at 08:14 AM |
as above, if your device supports SDHC you should be able to use all the way up to 32Gb
but if it doesn't then 2Gb is your limit
I'm in the same boat, looking
for an internal multi card reader to fit a 3.5" or 5.25" bay....
[Edited on 15/12/09 by mcerd1]
iank
| posted on 15/12/09 at 04:19 PM |
linky
Anonymous
| posted on 15/12/09 at 04:46 PM |
Darren
FAT16 can support up to 4GB volumes (with a lot of wasted space if you store lots of small files), but this probably isn't the issue.
The main problem is that SDHC and plain old SD use a different addressing scheme. A device that supports SDHC can use SD cards but not the other way
around, unless the manufacturer provides a firmware upgrade.
mcerd1
| posted on 15/12/09 at 05:37 PM |
linky
thats the sort of thing
this seems to be the new version with SDHC support: other linky
I've got 3.5" floppy drive at the moment with a 6 in 1 card reader built in (nice neat and cheap generic thing) but it doesn't do
SDHC
iank
| posted on 15/12/09 at 06:34 PM |
linky
SDHC
Haven't used a floppy disk for 10 years, and 1.44M seems almost comical today
The one I posted claims to support SDHC, but that one supports M2 and MicroSD if you ever get a new phone that uses those.
Anonymous
mcerd1
| posted on 15/12/09 at 07:30 PM |
I still use floppys on some old machines for booting etc, but I guess don't need it on the new one
I've had the microSD cards for ~6 years now - got a 16Gb in the phone now (full of tunes )
and one of them came with this tiny wee thing for nowt its really useful:
linky
