Author: Subject: Planning Permission Required?
Ben_Copeland
posted on 22/12/09 at 08:07 PM Reply With Quote
My next door neighbour is blocking up the sides of his lean to. Half of it will be office and half a storage.
His house has already had a kitchen extension and large conservatory. So almost certainly Over the threshold for extending without permission.
My question is does he need planning permission to change from lean to, to perminate Walls? It already had brick columns.
Plus his guttering is over hanging my drive, which will soon be becoming my garage as I am building aswell.
Can I ask him to move it or can he say no and I can't do anything?
Ben
Locost Map on Google Maps
Enter Your Details Here
MakeEverything
posted on 22/12/09 at 08:10 PM Reply With Quote
Does it affect you? If not, does it matter?
If it does affect you, speak to the planning office, or local authority.
Kindest Regards,
Richard.
nitram38
posted on 22/12/09 at 08:15 PM Reply With Quote
Talk to him first!
blakep82
posted on 22/12/09 at 08:17 PM Reply With Quote
Originally posted by nitram38
Talk to him first!
yes! don't go striaght to planning or it'll start all sorts of on going arguements
________________________
Ben_Copeland
posted on 22/12/09 at 08:18 PM Reply With Quote
Well my thoughts were, as we seem to get on ok I didn't want to cause him problems if the local council come round to look at mine and see what he's recently they might tell him to take down. Bearing in mind they've already visited and taken pictures for my planning permission.
The guttering does affect me as it's in the way. There's no point in asking the council because they take forever to reply.
Ben
posted on 22/12/09 at 08:20 PM Reply With Quote
should be easy enough to remove his guttering as yours goes up and fit some sort of valley for drainage if yours goes higher?
iank
posted on 22/12/09 at 08:23 PM Reply With Quote
I believe he does, and that they are quite unhappy about people turning car ports into garages.
He's not allowed to put his guttering over your property, and you can make him re-route it at his expense (this happened to my BIL). IIRC if you leave it too long without complaining then they can claim implied permission or somesuch.
One thing to be careful about is that these situations have the potential to turn quite nasty. For example if he decides that you've reported him to the planning office he's likely to get a bit 'grumpy'.
Depending on personalities these things can grow out of all proportion, fabricated complaints about noise etc.
If there is any kind of dispute then you/he are required to tell people when you/they come to sell. This can reduce the attractiveness of your property to buyers and from there the value. Tread cautiously would be my advice.
Anonymous
Ben_Copeland
posted on 22/12/09 at 08:24 PM Reply With Quote
Did think about a valley, but didn't want to be responsible for alterations to HIS guttering later on. I'm planning on asking about the guttering next time I see him, but wanted to know where I stand if he decides to get shitty
Ben
iank
posted on 22/12/09 at 08:26 PM Reply With Quote
Talk to him first!
But if he tells you to get bent then he'll know who told planning about his building without permission. That will be even worse. Can't really feign ignorance when he blows a gasket.
Anonymous
Ben_Copeland
posted on 22/12/09 at 08:28 PM Reply With Quote
Unfortunately the guttering his been there as long as the car port. Which was there before we moved in couple years ago. It's only really become an issue as it's now in the way!
Ben
posted on 22/12/09 at 08:55 PM Reply With Quote
He is well out of line sooner or later it is going to bring him trouble, even if he didn't need planning permission he requires a building warrrant, anything built with bricks/blocks other than the very lowest non-structural dwarf garden wall requires a building warrant.
Almost certainly his existing brick pillars are outwith his planning permision and it would surprise me if either or both kitchen extension and large conservatory are likewise.
You need to do some research then speak to him, if he dosen't back down hit him with the council.
In our cul de sac we are having a major problem with a couple who just do whatever they want without regard to the street don't want to say much about this at the moment but with a group neighbours we are standing firm about to seek a legal remedy.
[Edited on 22/12/09 by britishtrident]
posted on 22/12/09 at 08:57 PM Reply With Quote
I wonder if the people you bought the house from had problems with him ?
StevieB
posted on 22/12/09 at 09:02 PM Reply With Quote
If you get on OK, it's worth jus ahving a chat with him and letting him know your plans - if anything you might be able to do both jobs at the same time and get a better result.
You can also let him know you're going through planning for your project at the moment to give him a heads up of a potential problem if they ping his extension for what it is.
With regard to the gutter, it won't cost you any more to build some sort of valley to rectify the problem.
I have a similar issue myself - my neighbour had a kitchen extension and his outer wall became a party wall, so I own it (because we want a similar extension one day and will build straight off it). However, his plumber made the boiler overspill poke out through what is now our wall and it would overspill onto our land.
Now, I could make a big deal of it and have him re-route it internally to flow somewhere else. Or, since it never overflows anyway, I could just leave it, remain friends (we help each other with DIY projects all the time) and route it through my own extension as/when we have it done.
trextr7monkey
posted on 22/12/09 at 09:08 PM Reply With Quote
Not an expert but we replaced a legally built conservatory with a lean to roof with a much larger pitched roof including dwarf wall, with supporting steel work without the need for planning permission. We did need building control ofifcer though who was interested in calculations for steel work and where was the rain water piped to.
As above re being extremely diplomatic, guy doing our work put a scaffolding tent over the house which gave the impression we were adding a further 2 storeys, my daughter noticed 2 very well dressed blokes poking around one morning after we'd gone to work, presumably tipped off by a public spirited passer by
good luck
Mike
se7en
posted on 22/12/09 at 09:13 PM Reply With Quote
I had the same problem only in reverse- my guttering was overhanging the next doors premises.
If the guy had come and asked me to remove/change it, I would have without any further ado.
He sent me a solicitors letter about how much distress this overhanging guttering was causing him.
I eventually removed the guttering but the two of us never spoke to each other ever again. I made his life a misery so much so he moved house shortly after.
The lesson to learn from this episode is as BT says
IT'S GOOD TO TALK
Steve G
posted on 22/12/09 at 10:30 PM Reply With Quote
I'd say its "Dont move on next to Mr Se7en"!!!
[Edited on 22/12/09 by Steve G]
Ben_Copeland
posted on 23/12/09 at 07:10 AM Reply With Quote
As far as I'm aware, they moved in about 6 months before us and ours was a repossession. So was empty. They didn't do anything extending themselves.
One thing I do know is he's goin to have real trouble selling it if there is no certificates etc.
Ben
clanger
posted on 23/12/09 at 07:18 AM Reply With Quote
Do some research of your own on the Party Wall Act
[Edited on 23/12/09 by clanger]
plantman
posted on 23/12/09 at 07:38 AM Reply With Quote
I am no expert but we have have loads of dealings with planning over the years.
With all these things I agree with everybody else it is good to talk.........except if you don't like the overhanging gutter then i am sure if i was coming to buy your house then i am certain i wouldn't like it either so it will depreciate your property, and once money comes into it you are going to have a row!!
he may or may not have needed planning for his extension lean to etc, But he would have needed to see/submit plans to the building regutions/control officer, he will decide if they can escape in a fire enough ventalation/ light etc.
also last may/april in wales ( i am sure there will be something similar in england) with all new builds extensions alterations you have to submit a design and access statement( all to do with enviromental impact etc & access!!) bottom line is you need a professional to do this!!!
I am very confident you could ask him to remove the gutter if it is overhanging your property, I know this is the case if it is a tree shrub or edge, the only trouble is you will need him to do something about the roof water, but I know that is has to.
Anyway fairly straight forward just ring up the council and ask to speak to a planning officer, explain your problem to them they/you may decide that a site visit is needed.
these things always take ages, let us know how you get on and..
Best of Luck
contaminated
posted on 23/12/09 at 09:40 AM Reply With Quote
Probably dealt with above but yes he would need Planning Permission and he'd also need to comply with Building Regulations since the space will become habitable. I agree that it's good to talk these things through, but if you have no luck you need to contact your Planning Department.
Once it's built, although the Council could insist he knocks it down, this is in nobody's best interest and it would take ages. Additionally once it's been standing for a while and there have been no complaints it's possible to argue a case that it's legal under the Town and Country Planning Act.
Funnily enough when I bought my house there was no Planning Permission for almost the same thing. I have an extension and garage that started as a Planning Permission for a "covered walkway". My choices were to take out an indemnity against it (to cover demolition, planning and re-build costs if the Council ever came knocking - which I did) or try and prove it's legal. If I did the latter it would null the indemnity, so I've not bothered.
Liam
posted on 23/12/09 at 11:49 AM Reply With Quote
You sure that's just an 'overflow'? If he's had a new boiler fitted on that wall, and that pipe comes straight from it, it's more likely the emergency pressure release valve discharge! Make sure you haven't got any kids poking around anywhere near it if it ever does blow and dump pressurised hot water everywhere. The potential danger is exactly why those pipes are commonly routed to outside away from people near the appliance in the first place.
Whatever it is, having any sort of drainage like that routed to a neighbour's property is stupid, as how can the owner maintain it? Especially if it becomes built into the plumbing of your future extension!
Liam
[Edited on 23/12/09 by Liam]
