Author: Subject: Sky sat dish / LNB
jacko
posted on 29/12/09 at 09:30 AM Reply With Quote
Sky sat dish / LNB
Hi all can any one help me please my Mum & Dad's sky is playing up
when i go on the set up to look at the signal strength & signal quality the signal bars are all over the place moving up and down
Is it the LNB or just the dish that has moved with snow/ ice
Graham
Ps the picture is breaking up
[Edited on 29/12/09 by jacko]
gingerprince
posted on 29/12/09 at 09:40 AM Reply With Quote
If it's Sky+ i.e. has 2 separate wires, then try swapping them round at the box - if it's the LNB, chances are it's only one of the LNB's (or wires) that's faulty. If it's the same the other way round, then it is likely the dish has been misaligned as you say with snow.
mookaloid
A good site for this stuff http://www.satcure.co.uk/
Mark
jacko
posted on 29/12/09 at 09:48 AM Reply With Quote
Its only got one cable going to the LNB
ashg
posted on 29/12/09 at 09:50 AM Reply With Quote
what make is the sky box? there are a few that have problems with their internal tuners
Haynes Roadster (Finished)
Exocet (Finished & Sold)
New Project (Started)
mookaloid
posted on 29/12/09 at 09:53 AM Reply With Quote
I would test the box on someone else's dish first.
If it works you know it's either the cables, connectors, dish alignment, or LNB.
If it doesn't work on someone else's dish then the box is faulty.
Mark
jacko
posted on 29/12/09 at 09:56 AM Reply With Quote
I think its a Tomson i cant get to look at the mo
jacko
posted on 29/12/09 at 09:58 AM Reply With Quote
Mark
Hi Mark it looks like i will have to go and get it to try it at home
graham
splitrivet
posted on 29/12/09 at 10:03 AM Reply With Quote
If its windy where they are at its probably that plus a bit of dish out of alignment.
Bob
mookaloid
posted on 29/12/09 at 10:06 AM Reply With Quote
Mark
graham
Yes - Process of elimination I think
Mark
MakeEverything
posted on 29/12/09 at 12:33 PM Reply With Quote
There was a lot of trouble with the Thompson box, and the dish may have moved, but they are normally pretty tight.
Get a signal meter from B&Q and test the signal by removing the box and plugging it in. This is the PROPER way of testing the LNB.
The LNB incidentally, isnt the wires, but is the receiver that sticks out in front of the dish. They do go, and a replacement can be had from Maplins for a relatively low price. Maplins may be a better option for the signal tester also.
HTH.
Rich.
Kindest Regards,
Richard.
posted on 29/12/09 at 12:37 PM Reply With Quote
Slacken the screws on the LNB and try rotating it a bit if you can get at it while someone is watching the bars on screen. When I did ours it shot up to 90% signal quality from a very mobile 43%.
splitrivet
posted on 29/12/09 at 01:28 PM Reply With Quote
What he says, The cheapo Sat finders are analogue andwill only give an indication of the Sat position its signal quality you need.
Bob
