Author: Subject: Wheel Stud Lengths
avagolen
posted on 31/12/09 at 08:17 PM Reply With Quote
Wheel Stud Lengths
Happy new year to all you learned peep's on this mighty forum.
I have a question about the length of studs in my Sierra hubs.
1) If I want to fit a set of alloy rims, should I fit longer studs than standard?
2) How long?
Many thanks in anticipation.
Len.
flak monkey
posted on 31/12/09 at 08:22 PM Reply With Quote
You should have full thread engagement on std open nuts, which IIRC is about 12mm.
As long as you have enough thread engagement there is no need to change the studs.
Normally you will need longer studs on cortina front uprights though as they have particularly short ones as std.
Sera
http://www.motosera.com
plantman
posted on 31/12/09 at 08:40 PM Reply With Quote
I used 63mm but they are a bit too long, but I can chop them to suit
dlatch
posted on 31/12/09 at 10:02 PM Reply With Quote
depends on the alloys your fitting but on cortina hubs i found 63mm ones to be way too long and also have a longer unthreaded shoulder.
what worked for me was the 47mm ones
avagolen
posted on 1/1/10 at 07:59 AM Reply With Quote
Thanks everyone.
Len.
