Author: Subject: weight of borg warner range rover transfer gearbox?
NS Dev
posted on 15/1/10 at 02:41 PM Reply With Quote
anybody know the weight of a range rover borg warner transfer gearbox, on its own, perferably without the brake drum assembly?
cheers
Nat
boggle
posted on 15/1/10 at 02:43 PM Reply With Quote
around 60kg
u2u me for details
NS Dev
posted on 15/1/10 at 03:22 PM Reply With Quote
ooh not light then............
NS Dev
not much in it to weigh that much!
MikeR
posted on 15/1/10 at 04:42 PM Reply With Quote
left you a voice message saying this ....
had a chat with the office land rover expert.
range rover / defender / discovery / satanda (i don't know, i can't read my note) all use the same box with variations. Its the LT230.
It weighs about 8 to 12 kg.
the difference between the boxes is either the gear in side or the flange PCD. The boxes in a range are all identical - eg all range rover boxes irrespective if they're diesel / manual / auto / petrol are all the same and interchangable.
posted on 15/1/10 at 05:59 PM Reply With Quote
Originally posted by boggle
around 60kg
that wold be for gearbox;
transfer box I;d say, comparing series one, will be around 20 kg.
NS Dev
posted on 15/1/10 at 07:45 PM Reply With Quote
I'd guessed around 30kg based purely on size and contents, but wondered if anyone had an accurate figure? I think 20 is the most likely suggestion so far... As long as it's less than 40ish then I'll be happy
jambojeef
posted on 15/1/10 at 08:13 PM Reply With Quote
From having wrestled one out the Disco when our diff lock got stuck last year I would reckon in the 30kg range.
I would be surprised if it was as much as 40kg.
Are you knocking up a special proj. cos there were some nice transfer boxes attached the rear of BMW gearboxes on the board recently - sorry cant remember where though.
Geoff
locoboy
posted on 15/1/10 at 08:44 PM Reply With Quote
Deffo not 60kg, more like 30kg, i shift these around by hand enough to know they are not 'that' heavy.
Locoboy
Wheels244
posted on 15/1/10 at 08:51 PM Reply With Quote
Just sent one to the Scrappy with the main gearbox - nothing wrong with it either.
NS Dev
posted on 16/1/10 at 01:57 PM Reply With Quote
Doh!!
If anybody has one laying around................
