Dickyboy
| posted on 6/5/10 at 10:11 AM |
Coil spring questions
I have a trailer with coil spring suspension which has lost its oooomph. Do you guys know of a generic coil spring seller/source? or how I can refresh
the spring? I reckon its lost 30mm in length and probably quite a few pounds of strength. How do I calculate what compression strength it needs, based
on weight supported and compression length I would suppose?
| posted on 6/5/10 at 10:24 AM |
Can of worms there, do you not know the original spec of the trailer?
If not you can work it out by length and diameter then how much weight they need to carry.
Tons of places to buy new springs...
