posted on 9/7/10 at 07:34 PM |
A spot of demolition!
So, a rare 24 hours without work, Omex in Bumper? New sump? Bit of welding on the 4x4?
Why no! How about starting some thing new? YES!
6.30 this evening...
(Lime stone fireplace for sale by the way!)
Barely 2 hours later with the help of Mr. Prisebar and his mate 14lb Mel we are here...
Q? What's the best stuff to get rid of the soot on the back there? I'm thinking odf plastering or maybe rendering it with stone or bricks
etc and don't want the soot to appear in few months time
Ta,
blakep82
| posted on 9/7/10 at 07:36 PM |
bit extreme just to clean up the back of the fireplace isn't it?
________________________
55ant
| posted on 9/7/10 at 07:38 PM |
jet wash.
away from cars, now cycling and building TT bikes
jambojeef
| posted on 9/7/10 at 07:41 PM |
Woah nice work!
We've got some great stuff what we use to get the soot off the back of the stove doors - its a gel type stuff which you sort of spread on then
wipe off a bit later. I think its made by stovax the guys what made the stove?
Geoff
speedyxjs
| posted on 9/7/10 at 07:51 PM |
Brake cleaner with clear that lot up nicely
| posted on 9/7/10 at 07:54 PM |
Never mind all that... is that 'The Best of The Cheeky Girls' I see in your CD rack!?
It's Evolution Baby!
blakep82
| posted on 9/7/10 at 07:55 PM |
quote: Originally posted by jambojeef
Woah nice work!
Geoff
would that work because the backs of stove doors are really smooth? like glass or enamel or whatever? don't think it would work well on brick.
what about a wire brush in the angry grinder (yessss, it'll be messy though) then plaster?
| posted on 9/7/10 at 07:59 PM |
I just brushed the loose off ours then wet it and rendered it and it's nor reappeared in 4 years.
Liam
| posted on 9/7/10 at 08:00 PM |
Wire brush off what's loose, then go over the rest with PVA/primer. Then plaster (should be mortar if you plan to put a fire in there).
Should have gone to spec savers, that's "The Best Of Chesney Hawks" no the Cheeky Girls
StevieB
| posted on 9/7/10 at 08:02 PM |
How about a spot grit blaster? The type used by bodyshops to clean up stone chips etc. (has a vaccuum recovery for most of the grit).
They're about £20-30 and should clean up the bricks quite nicely.
If you want it doing faster, use a normal grit blaster and enclose as much of the area in polythene as possible (or you'll be cleaning sand up
for years to come!)
r1bob
| posted on 9/7/10 at 08:20 PM |
that was a perfectly good fire place .lol. are you fitting a beer chiller.
designer
| posted on 9/7/10 at 08:25 PM |
Brush soot off, then seal with a couple of coats of PVA
| posted on 9/7/10 at 08:43 PM |
This is what we want it to look like
graememk
| posted on 9/7/10 at 08:45 PM |
so can you do that to any fire place to put a log burner in ?
| posted on 9/7/10 at 08:56 PM |
As long as your chimney is in good nick, yes. Otherwise a chimney liner is required.
The building reg requirements for the area around a stove are fairly clear-cut, e.g. you can't have any combustible material within a certain
distance, the hearth itself must be a certain thickness (depending on what's underneath), and so on.
Guess who had a wood-burner installed a couple of months ago...
jack_t
| posted on 9/7/10 at 08:57 PM |
how much for the old fireplace?
you haven't damaged it have u
may be interested
se7en
| posted on 9/7/10 at 09:01 PM |
Yes, but you must install a new liner in the chimney.
I got one fitted two year ago and it is absolutely brilliant; the heat from them is terrific.
[Edited on 9/7/10 by se7en]
| posted on 9/7/10 at 09:07 PM |
No damage, £100. Was attached with metal brackets and screws. Hearth was glued down with tile adhesive. Your welcome to come and see it (in bits)
Swap ya for a Rover V8 engine or a Landrover gearbox...
MkII
| posted on 9/7/10 at 09:29 PM |
you still looking for a landy gearbox steve?
| posted on 9/7/10 at 09:46 PM |
Our fireplace was used for coal for 90 years before, why does it suddenly need a liner to burn wood ?
| posted on 9/7/10 at 09:53 PM |
Wood gives off tar/creosote, which sinks into the brickwork. this can (a) soak through and stain your wallpaper in nice brown patches, and (b) catch
fire.
| posted on 9/7/10 at 10:01 PM |
Yep, do you have one? or know were I can get one cheep cheep??
MkII
| posted on 9/7/10 at 10:03 PM |
might just know where there is one if you u2u me your no. I'll find out about it and ring u tomorow. .m.
| posted on 12/8/10 at 10:02 AM |
Bumpty bump, a update report, some painting required to finish it
