Author: Subject: Painting Porous Block...
posted on 23/7/10 at 06:43 AM Reply With Quote
Think I'll start painting my garage this weekend... should have it finished sometime around Xmas!
It's a concrete block construction... I have the right paint, but what is considered the best way to apply it? Brush or roller???
It's Evolution Baby!
dilley
posted on 23/7/10 at 06:49 AM Reply With Quote
floor or walls??
posted on 23/7/10 at 06:52 AM Reply With Quote
Walls...
Guinness
posted on 23/7/10 at 07:04 AM Reply With Quote
Spray it!!
But if it came down to brush v's roller, brush every time (unless your blockwork is smooth faced and the pointing is excellent, then you might get away with a roller)
Mike
iank
posted on 23/7/10 at 07:05 AM Reply With Quote
Originally posted by Guinness
Spray it!!
Mike
+1
Anonymous
posted on 23/7/10 at 07:22 AM Reply With Quote
Hadn't thought of spraying!
Cheers!
l0rd
posted on 23/7/10 at 07:54 AM Reply With Quote
Empty the garage,
Leave the backet with the paint in the middle
Put some tnt in it.
Get out, close the door and set it up.
mcerd1
posted on 23/7/10 at 08:04 AM Reply With Quote
whats the right paint ? (I've just been using cheap emulson with some mixed PVA in it)
I found the roller was next to useless on mine and thats on old bricks that already have 10+ coats of paint - I've just been using one of those cheapo masonary brushes and its been working fine
posted on 23/7/10 at 08:07 AM Reply With Quote
I'll get the name for you later Robert... it was recommended by Johnsons paints in Edinburgh.
locobri
posted on 23/7/10 at 08:17 AM Reply With Quote
Originally posted by l0rd
Empty the garage,
Put some tnt in it.
Mr Bean fan? by any chance
James
posted on 23/7/10 at 08:23 AM Reply With Quote
Empty the garage,
Put some tnt in it.
Haha! I was just going to mention that episode too!
Only ever seen about 3 different episodes but I've randomly caught that one about 10 times!
MikeR
posted on 23/7/10 at 08:24 AM Reply With Quote
Masonry brush or decorating paste brush or fence painting brush.
All similar and seem to do a good job. When i did mine it was far easier than i expected and it makes a big difference.
posted on 23/7/10 at 08:29 AM Reply With Quote
It's just so gloomy in there with the grey-walls! Hopefully some white paint will brighten things up and encourage me to go in their more often!
It was only built last year and the biggest mistake was moving 'stuff' in straight away to ease storage issues. It should have been painted (walls and floors) at the time, but hey-ho...
All the odds and sods have just gathered and it's a tip! I also need to get the Ultima chassis / bodywork / engine down, so need to get it in order.
StevieB
posted on 23/7/10 at 08:41 AM Reply With Quote
I did this recently - I used normal cheap emulsion (the type you buy in massive vats from B&Q) and a large masonry roller.
Just slap it on really thick, and do 2 laps of the room.
Because I did my floor as well, I just gubbed it into all the corners and edges and tidies it up when I did the floor and ceiling (it's a built in garage, so has a plasterboard ceiling in there).
I did the same with the floor too - 2 coats of sealer (PVA mixed 1:5 with water), cut the edges in to get a neat finish then slopped the paint on with a thick roller leaving it to cure for 5 days before heavy use (but could walk on it after 6 hours).
Came out nice and, while I'd take more time and effort over decortaing my house, it's only a garage and I only did it because I had no car in there and it makes a nicer environment to work in.
I did try a spray unit (one of those Earlex type things) and it was beyond useless - had to water the paint down so much it was like spraying the walls with milk. £30 and a morning wasted. The reality is it only took my a couple of hours to paint the walls by roller (standard single garage).
mcerd1
posted on 23/7/10 at 08:46 AM Reply With Quote
I hope its suitably locost
I've spent all the money on a not-very-locost car, so the garage has to be very locost
I've got some of there floor paint (got a tin for free from a mate) I just hope it lasts my garage is 10' x 33'.......
Stott
posted on 23/7/10 at 08:56 AM Reply With Quote
I'm not talking to you anymore, I'm too jealous
At least my garage is already painted white!
l0rd
posted on 23/7/10 at 10:12 AM Reply With Quote
Empty the garage,
Put some tnt in it.
Not really
Just happened that this episode was on during my flight to Greece on Easter
