RoadkillUK
| posted on 8/8/10 at 07:06 PM |
Cracks in wall
I'm just 'redoing' the attic bedroom. The back wall used to have a fireplace in it but was blocked off many years before I moved
in.
Now as you can see, the house has moved over the last 100 years, I'm not to bothered about that but my question is; What is the best way of
covering these cracks (assuming the wall may move a little over the years)?
A. Use the tape the goes over the gaps between the plasterboard, the mesh type tape, then skim over the whole wall.
2. Plasterboard the whole wall over the top and skim.
iii. Dig out the crack and fill, then skim the whole wall.
or %) Tell me your ideas.
Thanks, Lee.
Roadkill - Lee
www.bradford7.co.uk
Latest Picture (14 Sept 2014)
tegwin
| posted on 8/8/10 at 07:16 PM |
Assuming.that.the.underlying.plaster.is.sound.and.not.blown.I.would.simply.use.some.polyfiller.sand.smoooth.and.paint
my.space.key.is.broken.hence.dots
www.verticalhorizonsmedia.tv
macc man
| posted on 8/8/10 at 07:27 PM |
Depends on the sort of finish you are after. To do it properly I would remove back to brick and plasterboard and skim. If not too concerned tape and
skim wall.
zilspeed
| posted on 8/8/10 at 08:17 PM |
Dig out the crack to see what's actually going on in there, then take it from there.
The most accomodating solution will be to strap the wall and line with plasterboard followed by your choice of skim coat or tape and fill.
I would want to know for sure what's going on before covering it again though.
Danozeman
| posted on 8/8/10 at 08:35 PM |
fill and sand down.
Dan
zilspeed
| posted on 8/8/10 at 09:17 PM |
quote: Originally posted by Danozeman
fill and sand down.
And it will come right back again in my opinion.
Mark Allanson
| posted on 8/8/10 at 09:42 PM |
why.don't.you.ix.the.ucking.space.key?
Mark Allanson
| posted on 8/8/10 at 09:43 PM |
sorry, my 'f' is broken
RoadkillUK
| posted on 8/8/10 at 09:58 PM |
Right then, I'll go with tape and a skim then, I'll let you know if it goes tits up
Roadkill - Lee
www.bradford7.co.uk
Ninehigh
| posted on 9/8/10 at 05:33 AM |
I'm sure there was a plaster that was a little rubbery so the house could move a little and it wouldn't re-crack.
Also one of my friends spent six.months.texting.like.that.cos.her.0.key.was.broken. No idea how she dialled numbers!
bigfoot4616
| posted on 9/8/10 at 07:44 AM |
as a plasterer i would open the cracks up a little and then fill them with bonding. then paint the wall with thistle bond-it before skimming.
i would never skim directly over an old wall like that. seen it blow of to many times but thistle bond-it painted on works very well.
v8kid
| posted on 9/8/10 at 09:48 AM |
Cracks don't look too bad. A rule of thumb I used to go by was if you can't get your fingers through the crack it's superficial. If
you can - worry.
Go with the raking out and bonding prior to a skim. There are proprietary crack stitching kits available based on stainless ties and epoxy filler
which are used when the underlying subsidence is stabilized but those cracks appear to be only cosmetic and not worth loosing sleep over
You'd be surprised how quickly the sales people at B&Q try and assist you after ignoring you for the past 15 minutes when you try and start a
chainsaw
zilspeed
| posted on 9/8/10 at 04:40 PM |
Whilst the cracks may very well be superficial, they are certainly wider at the top than at the bottom. I wou;dn't be prepared to comment
further without much more evidence, but this is often symptomatic of an underlying defect.
As I said previously, it's absolutely worth your while checking the condition of the substrate to assess the condition whilst you're down
at this level.
One last thing.
Do you live in an area susepctible to shrinkable clay soil ?
JF
Building Surveyor.
| posted on 9/8/10 at 07:34 PM |
I know you are right John, but myself id just go for the cheap approach of poyfiller/easifill and stretchy paint. If it reappears, you've lost
nothing except a few hours, and if it doesnt, you've saved a day or a plasterer.
zilspeed
| posted on 9/8/10 at 09:02 PM |
You're not wrong.
My livelihood involves getting the diagnosis of this kind of stuff right, so it's in me now to look for the answer rather than hiding anything
that may be underlying.
Dosn't stop me from looking for a faster / easier / cheaper way of doing other stuff though
