Author: Subject: Odd electrical problem
smart51
posted on 28/8/10 at 05:24 PM Reply With Quote
The other night my bedroom light came on in the middle of the night. Switching the switch on and off made no difference so I removed the bulb and went back to sleep. This is a bit inconvenient so I bought and fitted a new switch today and it made no difference, so I removed the switch and with the wires bare, the light was still on. What is the problem likely to be?
There is a single twin and earth going to the switch so the ring main must be in the ceiling. What's going on in the roof?
Stuart_B
posted on 28/8/10 at 05:33 PM Reply With Quote
hi i would say that you have got a Permanent Supply at the light fitting, possible a cable has come out off the terminal and touch the switched side off the fitting, or if an old house has bare terminal blocks and now the loop side is touching the switched side.
i would turn the lighting circuit off, and look at the fitting wiring, or if it is in the loft go up there look for joints.
hope that is some help
stuart
RAYLEE29
posted on 28/8/10 at 05:55 PM Reply With Quote
definately sounds like a problem in the rose
Ray
smart51
posted on 28/8/10 at 05:56 PM Reply With Quote
The ceiling rose has 3 twin and earths in it. All 3 lives go to a common point. 2 neutrals connect to the neutral of the light fitting and the other neutral (with a red ring on it) connects to the live of the light fitting. All 3 earths are connected together. Nothing seems to be loose or shorting together.
Edit to say, disconnecting the live feed to the switch makes the light go off and disconnecting the neutral with a red ring on it return from the light both make the light go off. Am I right in thinking there must be a short in this length of twin and earth somewhere?
[Edited on 28-8-2010 by smart51]
GeorgeM
posted on 28/8/10 at 06:05 PM Reply With Quote
are there any mice in the loft??
My conscience is clear - I drive a GREEN car
MNR Racing
essexkitcarclub.com
smart51
posted on 28/8/10 at 06:06 PM Reply With Quote
If there are, do you think they are fried by now?
MakeEverything
posted on 28/8/10 at 06:18 PM Reply With Quote
The "Neutral with a red ring" is a switched live. Be careful. If you mix all these up its a good hour or two to sort it all out - for a sparks that is.
Kindest Regards,
Richard.
omega 24 v6
posted on 28/8/10 at 07:24 PM Reply With Quote
It could be the mice thing or the loose wire thing or the shorted out cable thing.
I have also seen in an old installation with steel conduit a scenario where the heat from the room caused condensation in the steel pipe ( in the cold loft the other side of the insulation). rust formed and fell into the fitting douing the same thing as you describe.
AndyO
posted on 28/8/10 at 10:04 PM Reply With Quote
have you got a picture above the switch? nail through cable?
FFTS
posted on 28/8/10 at 10:40 PM Reply With Quote
All wrong...
It's definitely Poltegeist.
My friend had one in the loft and they love to play the permanent light on trick.
Chris.
posted on 29/8/10 at 08:40 AM Reply With Quote
dont leave it on via the fault, its probably a poor link between the two that will be getting warm.
Multimeter from each end would tell you roughly where in the cable it is.
smart51
posted on 29/8/10 at 01:06 PM Reply With Quote
Ooo! How does that work?
posted on 29/8/10 at 02:44 PM Reply With Quote
mcb off and check its safe to work on. Then get the switch drop (the sleeved one), disconnect at both ends. Measure continuity between the red and black conductor from at each end. With no fault there should be no conductance at all (ie high resistance). Your fault implies a link somewhere between them. You are measuring up one leg, through the link and back down the other. The lower reading indicates which end the link is nearer to, and the difference between the readings is an indication of how far from the middle it is.
tbh though im not sure how a randomly appearing fault like this would be caused, as mice nibble insulation, they dont tend to link conductors together. Would deffo check the cable in the loft, and make sure no picture hooks etc have been fitted recently.
smart51
posted on 30/8/10 at 10:55 AM Reply With Quote
I took the loft boards up today and immediately found the problem. The metal conduit up from the switch was higher than the rafters so the boards were pressing the cable into the metal and had cut through the insulation. A new length of twin and earth and its all working again. We've been here for 10 years so the insulation has stood up quite well considering.
omega 24 v6
posted on 30/8/10 at 11:51 AM Reply With Quote
Erm the conduit should be earthed??? it'd the have blown the fuse.
Scenario where you go into the loft and grab the now live conduit is not a good one.
smart51
posted on 30/8/10 at 12:57 PM Reply With Quote
That's a good point actually. I trimmed the conduit back so that the floor boards cover it without pinching the cable but they should be earthed and clearly they are not. I'll have to get on to that.
posted on 30/8/10 at 07:28 PM Reply With Quote
generally the conduit doesnt have to be earthed as its not exposed, metal capping too doesnt need earthing. The terminal screws will often be the only exposed metal part of the drop, and these are earthed via the earth connection in the backbox. The conduit and cable should be fitted so that it doesnt pinch or chaff.
That said, earthing is probably a good idea.
Its a trade off against plastic conduit which doesnt conduct but also doesnt provide as much mechanical protection.
omega 24 v6
posted on 30/8/10 at 08:54 PM Reply With Quote
Obviously not in this case and IMHO not in many more that I have seen. Another big problem is plumbers who cut into copper pipe and then use plastic fittings. They very often dont bridge the two copper ends again.
