ali f27
| posted on 19/9/10 at 09:02 AM |
fridge
Hi anybody know about fridges mine playing up cheers
MakeEverything
| posted on 19/9/10 at 09:11 AM |
A little bit. Whats it doing (or not doing) - Other than refrigerating! ?
Kindest Regards,
Richard.
theconrodkid
| posted on 19/9/10 at 09:19 AM |
i once wrote a poem about one called horrace
who cares who wins
pass the pork pies
40inches
| posted on 19/9/10 at 09:32 AM |
Make, model and problem would be a help
However, if it is a so called "frost free" fridge/ freezer with fan in freezer, and the fridge is not cooling, but the freezer is, defrost
it for 24hrs, that works 90% of the time
RazMan
| posted on 19/9/10 at 09:38 AM |
There is always a piece of cheese behind it
Raz
| posted on 19/9/10 at 09:40 AM |
Not in mine , I only keep the beer in it. Had problems once with an old fridge that kept icing up, it was the door seal not sealing.
Danozeman
| posted on 19/9/10 at 10:15 AM |
As said whats it doing?
Iv just put a defrost heater in the freezer of mine because the freezer wasnt freezing very well and the fridge wasnt that cold. Also fitted a door
seal while was at it. Eve a slight gap is enough to let heat in and freeze it up.
A defrost would solve it for a while but it would frost up again.
Dan
Ninehigh
| posted on 19/9/10 at 12:16 PM |
Give it a kick or put it on the naughty step depending on your style
iank
| posted on 19/9/10 at 12:35 PM |
If there's water at the bottom it's probably a blocked drain hole - pipe cleaner with a little bleach on it (to kill the mould
that's usually the culprit) sorted mine.
Anonymous
MakeEverything
| posted on 19/9/10 at 12:47 PM |
Can anyone tell him how long that proverbial piece of string is as well?
Ninehigh
| posted on 19/9/10 at 12:49 PM |
Twice the distance from the middle to the end.
Or is it 20 minutes?
