sebastiaan
posted on 23/9/10 at 08:23 PM |
LDPE repair
Guys,
I've got a chance of some cheap garden chairs, but one of them has a crack in the corner of the seat base and would not be useable without a
repair. They're marked "LDPE" and are thus low density polyethylene. Some googling suggests it won't be easy to plastic weld
and the material also seems a bit thin to attempt this. There is however excellent access to the backside of the crack (err.... ;-)).
So; two questions:
1) What would my chances of achieving a solid and lasting repair be if I stuck a bit of fibreglass to it?
2) Is there another way to sort this out?
Thanks!
Ninehigh
| posted on 23/9/10 at 08:43 PM |
Would it be possible to wrap the crack in fibreglass? I imagine if you can get a decent bond to the plastic you'd be fine.
Richard Quinn
| posted on 23/9/10 at 09:10 PM |
As far as I know, LDPE should be weldable in the same way that we do MDPE and HDPE on pipework installations in work. You can even get LDPE welding
rods...
Linky
I could be wrong though but it may be worth having a go before you try the fibreglass wrap repair.
snapper
| posted on 23/9/10 at 09:24 PM |
I love polyurethane adhesive
I have repaired cracked pots with it and roof flashings.
Try bonding some mesh underneath the crack
I eat to survive
I drink to forget
| posted on 24/9/10 at 06:39 AM |
Drill a hole at the end of the crack as as crack arrestor no matter what repair method you choose.
boggle
| posted on 24/9/10 at 09:45 AM |
soldering iron to melt the bits together...
u2u me for details
