locoboy
| posted on 7/11/10 at 12:38 PM |
Have i knackered my fridge?
I have one of these fridge freezerslinky
I was defrosting the freezer section with an ice scraper and i punctured the ally skin inside the freezer compartment and the refridgerant started to
escape!
Is this sort of damage repairable these days or is it a new fridge freezer ?
Cheers - oh i got one hell of a bollocking and a big 'I told you so' in reference to melting it to defrost it!
Locoboy
mangogrooveworkshop
| posted on 7/11/10 at 12:43 PM |
you are a smeghead!
unless you can get parts its done
Humbug
| posted on 7/11/10 at 12:45 PM |
You're not the first (man) to do that and you won't be the last... mind you I've only done it the once
Surrey Dave
| posted on 7/11/10 at 12:49 PM |
Yep!
I did that a couple of months ago 'saving time' with a hammer and chisel!!! Really!
No I wouldn't use the above tools on a fridge of that value!
[Edited on 7/11/10 by Surrey Dave]
big_wasa
| posted on 7/11/10 at 12:50 PM |
Yep ive done it but not to a fridge of that value. Mine went to the tip.
l0rd
| posted on 7/11/10 at 01:06 PM |
Hair dryer or even better a heat gun if you have one.
Don't know if you can repair it.
Danozeman
| posted on 7/11/10 at 01:14 PM |
Its had it. I did it using a knife to defrost mine. Just after id been shopping a bought a load of frozen food!! Im aging the bollocking i got.
Best way is to turn it off over night with the door open.
Dan
splitrivet
| posted on 7/11/10 at 01:17 PM |
Banjaxed it I'm afraid, years ago when I was a fridge engineer there were a few repair kits to fix this sort of damage but I never had any joy.
Once the gas escapes moisture gets into the system and no amount of vac pumping gets it out and gives a long term fix.
Might be worth calling a local Smeg repair guy and finding the cost of a new evaporator with fitting.
Bob
| posted on 7/11/10 at 01:19 PM |
I've also done that Defrosted my ex GFs fridge with a chisel. Whoops.
karlak
| posted on 7/11/10 at 01:27 PM |
Why was there Ice to scrape away. It says from the link it is Frost Free. Never had any Ice build up with our frost free fridges.
Type: Free Standing Retro Style Fridge Freezer
Model: Frost Free
Colour: Silver
MK Indy - 2litre Duratec - Omex 600 - Jenvey throttle bodies - ETB DigiDash2
austin man
| posted on 7/11/10 at 01:52 PM |
I used to use a steamer to defrost ours. I would say its booolixed could probably have it soldered but not sture whether anyone would regas it
RazMan
| posted on 7/11/10 at 02:39 PM |
My wife is a serial fridge killer - she's killed 2 of 'em in that way and they were both stone dead by the time she was finished! I try
not to leave her alone with sharp objects now
Raz
mangogrooveworkshop
| posted on 7/11/10 at 03:07 PM |
If it was icing up the drain could be blocked with crap......but its dead......so thats a thing of the past
MakeEverything
| posted on 7/11/10 at 05:12 PM |
Model: Frost Free
Colour: Silver
Frost is different to "Ice" apparently. Ive had that argument before.
Skip it. Youll not get it repaired within a reasonable budget for a new one.
Kindest Regards,
Richard.
