perksy
posted on 18/11/10 at 10:14 PM |
PAT Course - Any Sparks in the House ?
Looking at taking the C & G PAT course at the local college ( just to add to my engineering CV )
are there any sparks in the house that can tell me how long the qualification lasts before you have to redo the course ?
Have Heard its 3 years from somebody, but wanted to check with you lads
Perksy
RazMan
| posted on 19/11/10 at 12:01 AM |
As it is a City & Guilds qualification, I don't think it 'expires' as such, but may need a topup if new modules are introduced.
You can do the course in a single day now anyway.
Raz
nitram38
| posted on 19/11/10 at 12:13 AM |
Too be honest its not a requirement to have the qualification and is mostly for non-electricians
tegwin
| posted on 19/11/10 at 08:59 AM |
Which is a little worrying really... a days course and then you have the authority to test electrical equipment and say if it is safe or not.... I did
the course with some colleagues and some of the things they were missing when back at work doing testing was scary!!!
www.verticalhorizonsmedia.tv
owelly
| posted on 19/11/10 at 09:52 AM |
The company I work for has just sent a bloke to do the PAT course. He's not 'skilled' in any discipline but found the course easy.
He can now plug things into the PAT test box and put a sticker on it. He can squint at it to see if the cables, casing etc are damaged but
that's about it really!
However, the course does not absolve anyone from liability. If some blokey (or blokess) takes the course, tests a piece of equipment which kills
someone a few minutes later, the company directors are still liable. If you happen to be the company director, sending yourself on the course would
only make things worse as you should know how to test stuff! It's then the directors job to justify to the courts why they employed a peanut to
do a skilled persons job. PAT ticket or no PAT ticket!
http://www.ppcmag.co.uk
nitram38
| posted on 19/11/10 at 10:16 AM |
"Competent" is the requirement for electrical work and is defined as someone with Knowledge, Experience & regular training.
MakeEverything
| posted on 19/11/10 at 05:11 PM |
THE HSE Guidelines on PAT testing say that anyone can do PAT testing with sufficient training. It doesnt need to have an electrical test, only a
visual and functional test.
INDG236 has all the information you need, available Here
Kindest Regards,
Richard.
gazza285
| posted on 19/11/10 at 11:32 PM |
PAT testing is a complete load of crap, wastes time, and does not prove an item is safe (or even if it works). It must cost our company thousands of
pounds, even though we test in house, and does nothing to improve the safety of the men using the equipment. Rant over.
martyn_16v
| posted on 20/11/10 at 07:49 PM |
On the other hand, in some environments PAT testing can be the only time some electrical equipment ever gets looked at until it actually catches fire.
I'm thinking offices full of non techie types who won't give a second glance to a cable with quite badly damaged mechanical protection,
buried in a rats nest of daisy chained extension leads.
Don't get me wrong, I hate having to PAT test all of the kit I look after, it's soul-destroyingly boring and mostly redundant given that
it's generally only ever touched by engineers who will recognise any defects in the course of their work. But, it does at least formalise a
process of making sure that everything does get a look once in a while, and leaves an ass-covering paper trail.
What really annoys me is the H&S nazi on most of the sites that we work on swearing blind that everything needs testing annually, which is
just wrong, and gives me a couple of weeks of unneccesary work a year.
