Author: Subject: Garage Alarm Heeeeeelp !!!
CRAIGR
Contributor
Posts 2769
Registered 30/8/05
Location Sussex
Member Is Offline
Photo Archive Go!
posted on 6/12/10 at 08:20 AM Reply With Quote
For some reason my garage alarm has started going off even when not set. All last night at random intervals it would chirp once or twice then stop so i went out and set it and it made no difference. Doesn't show on the board that its activated and the blue light on the box isn't flashing .
Any suggestions before the neighbours hang me ????
Could it be the battery in the bellbox has died ?
[Edited on 6/12/10 by CRAIGR]
rgrs
posted on 6/12/10 at 08:30 AM Reply With Quote
Open up the bell box, check the voltage suppy, but if it's intermittent and not setting of the tamper to the panel then suspect it's going to be corrosion or water ingress. Probaby time for a new box.
Roger
CRAIGR
Contributor
Posts 2769
Registered 30/8/05
Location Sussex
Member Is Offline
Photo Archive Go!
posted on 6/12/10 at 08:35 AM Reply With Quote
Thanks for that Roger i suspect you may be right after the amount of snow and then rain we've had. I shall have a look although from about 7am its stopped doing it . aaaarrrggghhh .
Best place to buy a reasonable bellbox??
How easy to wire a new one in ?
blakep82
posted on 6/12/10 at 10:08 AM Reply With Quote
our does that same thing when the battery needs replaced
________________________
CRAIGR
Contributor
Posts 2769
Registered 30/8/05
Location Sussex
Member Is Offline
Photo Archive Go!
posted on 6/12/10 at 10:23 AM Reply With Quote
Just been out to take the cover off of the bellbox and hear a clicking sound. Removed cover and its not a clicking its
a rather bright electrical flash from a capacitor on the board inside so its ferked.
Bellbox recommendations please gents
Needs to be compatible with an Optima compact system.
posted on 6/12/10 at 02:06 PM Reply With Quote
Could just be that the capacitor has bulged and let out the magic smoke ? worth trying to fix? Capacitors are cheap Suppose it depends how quickly you need it working and where your nearest RS / Maplins type place is....
CRAIGR
Contributor
Posts 2769
Registered 30/8/05
Location Sussex
Member Is Offline
Photo Archive Go!
posted on 6/12/10 at 02:16 PM Reply With Quote
Cheers Ben but to be fair its all pretty corroded in there unfortunately.
Considering getting a Honeywell ag8 intellisense box , any good??
rgrs
posted on 6/12/10 at 05:32 PM Reply With Quote
Save your money and use the ag6 or the ade version not woth paying more than £15.00 for one.
Roger
