Author: Subject: Can someone recommend a security camera and recorder system
John Bonnett
posted on 23/12/10 at 04:25 PM Reply With Quote
As title, I'd like to fit a security camera in our lane which can be wired back to the house which is 100yds away. Ideally I'd like a recording facility with playback via the computer. There are many options out there so a recommendation would be useful. Because of the trees etc in the way I think I've discounted a wireless system.
Any help here would be appreciated. Thank you.
John
Agriv8
posted on 23/12/10 at 05:02 PM Reply With Quote
Following with intrest
a bit of a hijack but on a similar vain sytems that could record to a NAS drive would be usefull Cat 5 wired ?
As our house security is getting updated due to earlier post
Regards
Agriv8
AndyW
posted on 23/12/10 at 05:07 PM Reply With Quote
I hope it is a private lane? Otherwise a security camera with recording system will need local planning consent.
ChrisW
posted on 23/12/10 at 05:14 PM Reply With Quote
One of my clients writes this: Zone Minder
I've heard lots of good things about. Just take an old PC, add a PoE-enabled IP cam and some CAT5 and you're sorted.
Chris
posted on 23/12/10 at 05:44 PM Reply With Quote
only if they notice the cameras! Its not quite the same as knocking up an extension without permission
John Bonnett
posted on 23/12/10 at 05:50 PM Reply With Quote
It's okay, it is our lane.
rgrs
posted on 23/12/10 at 09:51 PM Reply With Quote
Virtually all dvr's now give access to the stored Images via LAN access.
Have a look round Y3K's web site
I wouldn't expect a pc to last more than a few months recording video data unless you use server rated drives.
Also think about the power consumption running the pc.
Provided that the camera is on your property and the property is not listed then no planning is needed.
You are however required by law to register the system.
Roger
McLannahan
posted on 23/12/10 at 10:02 PM Reply With Quote
Roger
I've an account with y3k and it's been a good company to deal with. Prices are quite reasonable and stuff of quite good quality. It's easy to buy cheap crappy CCTV - far too easy.
I have this DVR and although you can get cheaper - much - it's been a good reliable unit.
http://www.y3k.com/product.php?xProd=4940&jssCart=669d3e1347225ae10f559a30f6167648 (I have the 1TB version)
John Bonnett
posted on 24/12/10 at 10:03 AM Reply With Quote
Thank you all very much for your replies.
John
