tegwin
| posted on 26/1/11 at 10:39 PM |
Drilled bolts
Anyone know where I can get drilled bolts from (if such things exist)
Basically an m6 bolt with a hole drilled down the middle so I can pass an electrical wire through the center of the bolt...
(not through the head, but through the actuall shaft...)
I cant realistically make them... I need about 1000 of the buggers...
[Edited on 26/1/11 by tegwin]
www.verticalhorizonsmedia.tv
MakeEverything
| posted on 26/1/11 at 11:05 PM |
Like Banjo Bolts or do you want the hole to go through the head AS WELL AS the shank?
Kindest Regards,
Richard.
NigeEss
| posted on 26/1/11 at 11:06 PM |
What length/material ?
A google for "M6 hollow bolts" found a few results, mainly alloy for deraillier applications.
ebay linky
PSpirine
| posted on 26/1/11 at 11:30 PM |
Incidentally, at $3 a bolt (that link above), it'd be far cheaper to get someone with a lathe to make up 1000 for you
tegwin
| posted on 26/1/11 at 11:38 PM |
Yeah, I am thinking that...
Or design a different solution that doesnt need the bolts... bugger...
smart51
| posted on 27/1/11 at 09:25 AM |
I've just had 2 M10 bolts drilled on a lathe for the same reason. You have to remember that the drilled hole will not be plated.
HowardB
| posted on 27/1/11 at 09:37 AM |
if you need a bolt manf, I can put you in touch with someone, they make bolts in the UK, and a hole down the middle should be only a small
challenge.
hth
Howard
mad4x4
| posted on 27/1/11 at 12:27 PM |
What about getting some tube and running a DIE up it to thread the outside?
Scot's do it better in Kilts.
MK9R
| posted on 27/1/11 at 01:06 PM |
A bloke in the workshop next door said he would supply them at a £1.10 a bolt??
Cheers Austen
RGB car number 9
www.austengreenway.co.uk
www.trackace.co.uk
Strontium Dog
| posted on 27/1/11 at 01:42 PM |
I can do them for you if you need them turned bud. We can discuss when you drop that jig back if you like.
Madinventions
| posted on 27/1/11 at 01:51 PM |
Lewvac stock drilled bolts. Link
Have a look in the online catalogue. No idea about price - sorry.
Ed.
View my band website:
http://www.shadowlight.org.uk
Alan B
| posted on 27/1/11 at 02:15 PM |
I'm puzzled how anyone could quote this TBH...I don't see a bolt length, or the required hole diameter...both VERY important pieces of
info. for quoting 1000 parts.
For example an M6 x 15mm long with a 4mm hole would be way cheaper than an M6 x 75mm long with a 2mm hole....extreme examples but you see my
point...
Unless of course I missed that info. in which case this post is pointless.......
Also, as NigeEss says .....what material?...very significant info. too.
[Edited on 27/1/11 by Alan B]
tegwin
| posted on 27/1/11 at 05:23 PM |
Haa... a man of many tallents..
Yes.. I do need to come see you and return your jig...
smart51
| posted on 27/1/11 at 07:10 PM |
point...
I'm not sure I'd like to drill a 4mm hole up a 6mm bolt. It doesn't leave you much margin for error. I take your point though.
