Author: Subject: Any TV experts? (ie signals, aerials, wireless bits n bobs)
DarrenW
posted on 14/2/11 at 01:42 PM Reply With Quote
Moving house next weekend. New house has sky dish up but no TV aerial (blew down, never replaced). We dont have Sky subscription - happy with freeview. Just wondering what our best options are. last owners just had one sky box feeding the whole house. I like the idea of being able to watch different programs in different rooms though.
The obvious solution is get Sky. The current sky box is in a bedroom and i think transmits around house with a magic eye type thing. Do these run through the co-ax cable? If Sky is broadcast around the house like that does it mean any TV connected to the co-ax sockets can see whatever the sky box is playing? I guess this means you have to be careful if you are watching a horror film etc as the kids could also be watching it in their rooms - not good.
I know i could just put an aerial up, will probs sort it out one weekend. Are all aerials basically the same? Ive put a high gain one up before from B&Q and installed a booster / splitter. Seemed to work well. I might try and rig one in loft until i can get big ladder (and brave legs!). What are the best signal boosters / wireless signal transmitters? (its a big house, apparently the magic eye takes a while to work the sky box from the living room)
How does freesat work? Can i use the existing sky dish and just buy a freesat box? i assume if you want to watch different programs on different TV's you need more than one freesat decoder box (sounds pricey).
I havent looked into multi room stuff much before, not sure where to start. i dont want to buy something from std diy shop to find it doesnt work very well. Thanks in advance for your ideas.
jossey
posted on 14/2/11 at 01:51 PM Reply With Quote
media centre or a quad lmb and a few freeview boxes.
we have sky subscription in the living room with a magic eye to our bedroom so when we in bed we can watch proper sky.
my daughter has freeview channels using our old sky box in her room.
cinema room has satalitte freeview which is all freeview channels.
then divx player in all rooms and network media centre to play off media centre pc in bedrooms and cinema rooms.
ps3 plays the media in the livingroom eg divx films.
hope that helps show what can be done.
dave j
David Johnson
mookaloid
Hi Darren,
You can get a freesky box for less money than putting up a new digital aerial - just plug it in to the sky dish and as long as the dish hasn't moved from the sky satellite it should work just fine.
You can even get freesky Hard drive recorders like sky plus if you have 2 dish leads and twin LNB
I run tv's in 3 rooms with 1 dish - you get mulitple output LNB's and run the cables round the house.
DarrenW
posted on 14/2/11 at 02:11 PM Reply With Quote
Thanks for fast replies.
Is freesky a certain type of box or simply a std skybox that you use to just get the free channels (ie no need to subscribe or have a card etc in the box)? Sounds like a easy solution to at least be able to watch something. I assume its just a simple case of getting on ebay (or similar) and buying an old box off someone.
mookaloid
posted on 14/2/11 at 02:32 PM Reply With Quote
Sorry Darren I meant to say freesat
http://www.freesat.co.uk/
This is an example of the box you would need to receive the signal New Triax SR110 Free To Air Freesat Satellite Receiver on eBay (end time 16-Feb-11 19:42:51 GMT)
Visit Our Shop For All your Camp
Mark
Humbug
posted on 14/2/11 at 02:36 PM Reply With Quote
I can't get Freeview here (supposed to be 2012...). Used to have a Sky subscription them when the kids grew out of Disney etc. I just used it as a Sky freesat box. The sky box lasted for over 10 years (!!) then gave up the ghost, so I've now got a Humax Foxsat HD - freesat (not exactly the same channels as the free Sky ones) and Hi Def on the relevant channels. I just had to unscrew the cable fro the sky box and screq it into the new box.
I've got an aerial on the roof for normal TV, then pipe the output from the Humax back up a cable to a splitter in the loft. That has feeds to various different rooms in the house. I set a certain channel on the individual TVs so we can watch whatever's on the Humax. Can't watch a different programme but that's not a big issue for us.
DarrenW
posted on 14/2/11 at 02:52 PM Reply With Quote
Cheers Mark. The one in that link are certainly far cheaper than i saw at the weekend (less than half).
Before you posted the link i did some googling and saw this
Sky Freeview / Sky Freesat No viewing card required on eBay (end time 17-Feb-11 19:09:01 GMT)
Also looks like a cheap option - obviously an old sky box that has been reprogrammed.
mookaloid
posted on 14/2/11 at 03:30 PM Reply With Quote
I think I'd go for the only slightly more expensive proper freesat box myself
Also probably easier to keep up to date with new channels etc and I'm not convinced that you get all the free channels that are available with the freesat box.
Edit: Cheaper one here GOODMANS GFSAT101SD FREESAT SD SATELLITE RECEIVER on eBay (end time 17-Feb-11 20:01:41 GMT)
[Edited on 14/2/11 by mookaloid]
jacko
posted on 14/2/11 at 04:45 PM Reply With Quote
And Darren now your over 65 years old you can get freesat for £20 of the government part of the change over to digital tv
Graham
DarrenW
posted on 14/2/11 at 05:01 PM Reply With Quote
Thats a bloody good idea Graham. Unfortunately im a few months off () but father in law could get one. How did you get yours?
jacko
posted on 14/2/11 at 05:53 PM Reply With Quote
Shush its on its way [ i hope ] to fit in the caravan shush
