Badger_McLetcher
| posted on 7/3/11 at 12:50 PM |
Miniature Hydraulic Motors?
Hey guys, as part of a Uni project I need to source some small hydraulic motors and I was wondering if anyone could point me in the right direction?
These need to be as small as possible due to clearance issues. Also the higher torque output the better
Cheers!
Badger
blakep82
| posted on 7/3/11 at 12:52 PM |
hard top convertible cars
peugeot 307cc and the likes
you can even have the hydraulic rams off them too...
[Edited on 7/3/11 by blakep82]
________________________
| posted on 7/3/11 at 02:03 PM |
They don't use hydraulic motors do they? Just a conventional electric hydraulic pump and rams AFAIK.
blakep82
| posted on 7/3/11 at 02:10 PM |
ooh, whats a hydraulic motor then? i thought they were another name for the electric pump thing (using electric motors rather than engine driven)
ah, for driving wheels with hydraulics, sorry
hughpinder
| posted on 7/3/11 at 04:13 PM |
You could try this site:
http://www.hydraulicsonline.co.uk/hydraulic-motors/omm-hydraulic-motor%20/omm-gerotor-125cc-hydraulic-motor-60.html
or rs has small gear motor which you can drive backwards of course.
regards
Hugh
Badger_McLetcher
| posted on 7/3/11 at 05:16 PM |
Ta for that guys After looking I reckon I'm gonna need a radial motor for the high starting torque, but I don't think they make them as
small as I need
tegwin
| posted on 7/3/11 at 06:40 PM |
If they are that small wouldnt an electric motor be a more cost effective and simpler option!?
www.verticalhorizonsmedia.tv
Badger_McLetcher
| posted on 7/3/11 at 06:46 PM |
Maybe, I'm after a high torque and compact motive power. Also needs to be as light as possible etc. I've always thought of small electric
motors as signficantly lacking torque. Also a hydraulic motor can't be back driven, which is useful in this application
Edit: Just realised I havn't said what it's for- it's a mechanical arm. Doesn't need massive power, only lifting about 75kg
or so.
[Edited on 7/3/11 by Badger_McLetcher]
bi22le
| posted on 7/3/11 at 07:03 PM |
We use electric driven rams at work. Also called actuators!!
Some of them are beasts and quite small.
I work with wheelchairs and rebab so look down that line maybe. Powered elevating leg rests and hoists are common.
[Edited on 7/3/11 by bi22le]
Please read my ring story:
