Author: Subject: Sorry wrong section....Locost Lathe Coolant
FASTdan
posted on 14/3/11 at 12:27 PM Reply With Quote
Whoops I've put this in the wrong section, can mods move please...
Thanks to Richard I am now the proud owner of a Denham junior lathe. I would like to rig a locost coolant system up. RDG tools do some decent flexi-magnetic coolant nozzles, and I plan to simply mount a coolant sump (bucket!) under the drip tray. So I just need a cheap submersible pump - am thinking £12.99 fish tank pump from ebay, but before I buy something entirely unsuitable has anyone got any tips?
[Edited on 14/3/11 by FASTdan]
NEW danST WEBSITE NOW LIVE! Bike carbs, throttle bodies and more......
http://www.danstengineering.co.uk/
Davey D
posted on 14/3/11 at 12:31 PM Reply With Quote
how about an old screen wash pump from a car? im sure there are a few people breaking donors on here that would have a pump kicking around
snakebelly
posted on 14/3/11 at 12:32 PM Reply With Quote
dont forget a filter on the inlet side of the pump or it will last a matter of minutes
paulf
posted on 14/3/11 at 01:36 PM Reply With Quote
I have used a central heating pump in the past,gives plenty of flow and a bit more swarf resistant than a fish tank pump.It can be placed outside the coolant tank and connected with a hose and inline filter if required.
Having said this I dont have a coolant pump on my lathe at home and either just use coolant in a squeezy bottle of use neat cutting oil.
I have worked on lathes in industry and find that with a coolant tank and lots of coolant flowing it tends to spray everywhere and makes everything smell of oil and also needs to be cleaned out on occasions.It is worth while getting some synthetic coolant rather than soluble oil as this smells less and performs better.
Paul
posted on 14/3/11 at 02:27 PM Reply With Quote
Same as Paul - I don't use the lathe's own coolant pump (a) because of the mess and the cleaning up, and (b) because it's hard to get it to work with the 3-phase converter - converters are made to suit the size of the motor you're using, and mine was bought to run the 1.5HP main lathe motor - the converter won't convert when only the 1/8 HP coolant pump motor is running. I could change the motor to a single-phase one and operate it directly off 1-phase, but I can't be bothered.
I use a hand sprayer (plant sprayer) to put a mist of cutting fluid over the work. If I twist the spray nozzle I can get a jet, which is useful for getting into corners (e.g. when parting off). I usually use diluted Rocol general-purpose cutting fluid, which is synthetic and doesn't have a significant smell (vaguely oily).
WD40 is quite useful for a quick burst of cutting fluid at short notice, useful with the long nozzle pipe, especially when turning aluminium (thanks to 907 for that tip!).
FASTdan
posted on 14/3/11 at 04:35 PM Reply With Quote
Fair comments, maybe I'll see how I get on with just a spray - coolant feeds are kinda messy.
fazerruss
posted on 14/3/11 at 06:09 PM Reply With Quote
Paul [/quot
Sorry to hijack the thread, Paul did you connect the pump to the bottom of the tank or did you just stick a
pipe in to the top of the tank . I assume the central heating pump wouldnt be able to syphon up unless already primed?
I need to make a system for my milling machine to keep the cutters cool.
"if assholes could fly this place would be an airport"
paulf
posted on 14/3/11 at 06:32 PM Reply With Quote
I fitted level with the bottom of the tank and fitted a pipe fitting into the bottom of the tank with a short hose, no reason why you could not have a pipe up and over the side of the tank as long as you primed it first though.
Paul
Paul [/quot
RAYLEE29
posted on 14/3/11 at 06:34 PM Reply With Quote
hi, i used a noisy old fuel injectiom pump with a pre filter connected to a battery cost nothing as i had all the bits
posted on 14/3/11 at 09:14 PM Reply With Quote
Hijack!
Where do I get the fluid please?
