Author: Subject: OT: 5.1 home cinema
UncleFista
posted on 18/3/11 at 06:31 PM Reply With Quote
OT: 5.1 home cinema
If I was to buy a 5.1 home cinema setup, would it work as "normal" stereo if I didn't want to bother with rear speakers or do I need to buy a 2.1 setup ?
Cheers in advance
Tony Bond / UncleFista
blakep82
posted on 18/3/11 at 06:44 PM Reply With Quote
yep, if you only have 2 speakers connected (or 3, as the .1 is the bass speaker) then it will only use 3, a left, a right, and a bass
mine has 2 sets of outputs, set A and set B
set A is plain stereo
set B is the surround set. but even with set B connected, you can still choose between 2 channel stereo and 5 channel surround
________________________
Danozeman
posted on 18/3/11 at 07:30 PM Reply With Quote
Yep. I use my panasonic one as a stereo. You can turn the speakers off you dont want. Most have a music setting aswell.
Dan
UncleFista
posted on 19/3/11 at 12:03 AM Reply With Quote
When I got it home it has a switch to change between 2.1 and 5.1 anyway
