Author: Subject: Which welder
JeffJeffers
posted on 6/4/11 at 10:35 PM Reply With Quote
Which welder
I have decided I want to buy a mig welder to help with my build. I have found this on ebay and its not to far away. Does it look any good for the money? SIEGEN MIG 150 MIG WELDER on eBay (end time 10-Apr-11 11:03:36 BST)
Mr Whippy
posted on 6/4/11 at 11:03 PM Reply With Quote
Yeah looks good and would be just fine for doing a chassis etc
You should however replace that rubbish mask with an auto tinting one, otherwise you'll soon enough learn about welding flash and just how painful it really is...
Turbo (just a cooling fan) ones are better for longer run times before needing a pause to cool back down
Do always turn of the valve on the gas bottle once finished or it will all vanish in a few days or less
It's best to have a look over the machine for wear and tear. Check for frayed cables, try pressing the trigger at a very low wire speed and see when it doesn't move, if that is at quite a high number say about 3 and it's still not moving or only moves when you wave the hand set about then the feed tube for the wire could be very worn. I have a spiral metal one on mine for the full length. Most have metal only at the top in the handset with plastic for the rest, this wears quite bad and makes the feed very erratic
Since the guy has done a fair bit of welding, just ask for a demonstration of a good weld or too, and listen to the machine, how smooth is the wire speed motor running. Off course you will have to bring a gas bottle with a regulator but you had to get that anyway.
iank
posted on 6/4/11 at 11:31 PM Reply With Quote
View over on mig-welding is it's Chinese and inferior to a Clarke, but that one is a very good price. Why's he getting rid after 18months? Upgrading?
http://www.mig-welding.co.uk/forum/showthread.php?t=3847
http://www.mig-welding.co.uk/forum/showthread.php?t=3701
Anonymous
SeaBass
posted on 7/4/11 at 09:15 AM Reply With Quote
I had a bust Siegen from Zilspeed - turned out the control transformer on the PCB was fried. I swapped it for an off board trafo with flying leads. The actual iron (ie the welding transformers) looked pretty good and chunky. Worked fine after that and wasn't too bad to use but as I'd acquired a Cebora Pocket Turbo 130 (very good and also sold rebranded by Snap On) I punted it to the artist formerly know as Dave1888.
JC
[Edited on 7/4/11 by SeaBass]
