Author: Subject: Screw caps
stevebubs
posted on 10/5/11 at 08:30 PM Reply With Quote
Screw caps
Put the new skirting up, screwed to wall. Screw heads are in 10mm holes, about 4-5mm below surface
Need to find a source of 10mm diameter, 5mm thick pine caps to hide them...
Any ideas?
stevebubs
posted on 10/5/11 at 08:31 PM Reply With Quote
PS Prefer off the shelf as I don't have that much spare time to make c. 150 of the little blighters...
mangogrooveworkshop
posted on 10/5/11 at 08:36 PM Reply With Quote
b an q do plastic ones
Thinking about it
posted on 10/5/11 at 08:41 PM Reply With Quote
I know you said off the shelf. But make your own with these takes seconds.
A dab of glue then plane or sand flush. Perfect job.
http://www.machinemart.co.uk/shop/product/details/cht367-8pc-d rill-plug-cutter-set
[Edited on 10/5/11 by Thinking about it]
lsdweb
posted on 10/5/11 at 08:42 PM Reply With Quote
10 mm core cutter in a pillar drill and an offcut of skirting - shouldn't take long!
Wood glue around the plug, tap it in with the grain in the right direction, leave it dry, sharp chisel to bring it just proud. Rub it down.
Done!
Wyn
Thinking about it
posted on 10/5/11 at 08:43 PM Reply With Quote
I think no nails would have been your friend not the screws.
stevebubs
posted on 10/5/11 at 11:03 PM Reply With Quote
When I want to remove it to run more cables, no nails will remove most of the plasterboard in my experience!!
stevebubs
posted on 10/5/11 at 11:48 PM Reply With Quote
Done!
Wyn
Will probably take me a couple of hours to get to the drill...have a Fury in the way in the garage, and an Omega blocking it in on the drive...oh..and the Fury is buried under piles and piles of what SWMBO has dumped on it....
lsdweb
posted on 11/5/11 at 06:34 AM Reply With Quote
Sounds like my garage!
HowardB
posted on 11/5/11 at 07:04 AM Reply With Quote
SWMBO doesn't have the key to my garage!! Much less "domestic" stuff in it
Howard
posted on 11/5/11 at 09:33 AM Reply With Quote
The voice of experience?
I was really chuffed with myself after taking the time to remove all the skirting before laying new wood floors then fitting new stuff with No More Nails (wanted to avoid the nasty look of additional strips of trim to cover the expansion gaps).
Then SWMBO decided she did want the swish 70's fake mantlepiece and hearth removing after all
Removing it was easy, as was lifting and relaying a section of floor to fill the gap. Removing and refitting the skirting was a grade A PITA. I spent longer repairing the damages plaster than I did on the rest of the job
DarrenW
posted on 11/5/11 at 02:33 PM Reply With Quote
I know boards no nailed on can remove plaster etc when pulling off. Not too bad though if you use it more sparingly rather than apply like tiling adhesive. however how do you easily remove the screws from screwed on skirting boards when you glue a cap over them the sand down etc and paint so you dont know where they are? Even if varnished the caps become part of the skirting so will need some form of removal to reveal the screw heads (whose heads hopefully arent filled with glue).
i must have been lucky when replacing previously no nailed woodwork in the past, even if plaster was pulled off quick application of the trade soft stuff meant they went back on easily.
posted on 11/5/11 at 06:02 PM Reply With Quote
i just use decorators caulk, its adequate for the job. Never had to remove any but it cant be too hard.
Had to change a bathroom sink just now that was only held on by silicone, eventually got it off in pieces with a mallet. People think its a bodge using silicone but it was definately more secure than one screwed on.
