daniel mason
| posted on 10/1/12 at 06:01 PM |
new lap top gone ultra widescreen, how do i change it?
turned my new toshiba laptop on yesterday and it just seems to have gone ultra widescreen when i go on line, i can hardly read the writing on the
forums as the page is so stretched.
how do i change back to original settings? am useless with computers! cheers
[Edited on 10/1/12 by daniel mason]
MikeFellows
| posted on 10/1/12 at 06:48 PM |
im guessing its windows 7 but its similar enough for xp/vista
right click somewhere on the desktop (not on a file), then click Screen Resolution
you should just have to drag the slider across to the right until its at its maximum, if not play about until you happy with it.
if you get it wrong and screen goes black - wait 15 seconds and it will revert back if you dont confirm.
Madinventions
| posted on 10/1/12 at 09:48 PM |
If you're using Internet Explorer, press Ctrl and '0' together to reset the zoom back to 100% in case it's got set really high
by mistake.
View my band website:
http://www.shadowlight.org.uk
daniel mason
| posted on 10/1/12 at 09:55 PM |
that worked instantly. thanks mate. nothing else seemed to work. at least i can see what im writing now.cheers
blakep82
^ good call, if its only on the internet, check the bottom right hand corner of the window, there should be a magnifying glass with a plus in it,
check the number next to it is 100%, not anything higher
________________________
Madinventions
| posted on 10/1/12 at 10:15 PM |
Glad you got it sorted It's really easy to accidentally set the zoom level too high because you can change it by holding down the CTRL key
and scrolling the centre mouse wheel up and down as I found out once!
